RS2000 I4 Engine,any good for turboing??
Hi, been thinking about turbocharging my rs2000, it seems to be a strong engine, and having a strong gearbox aswell, could i get away with using one of those de-compression plates, and a few other mods to the block for oil/water feeds etc,
Whats the efi mangenment like on rs2000s?, can the ecu be re-mapped to suit turbocharging?,
or is it best to rip the I4 lump out and build a zetec turbo engine?
you can get away with using a ferriday engineering decompression plate, but its a bit of a pikey situation and you can't run much over 9-10psi. You'll need to also find a suitable manifold. Then you can run the rest of it on FRST management as far as i'm aware.
BUt yes its best to run a ZT, cheaper, tried n tested
Motorsport Developments have built a circa 300bhp RS2000 turbo (was owned by Kenny @ M.D) - but it might well be easier to do a Zetec Turbo with so much info on them these days...
would my mtx75 box link up with a 2 litre zetec bottom end?
1 Post
Originally Posted by robrs2
Look for "Neil" on the Interford board. He has a 4i running one and its not a cheap thing to do.
Its the same engine and set as mine however he has low comp bottom end and MBE.
I run a the origanal Turbo Technics spec but tweaked to 200bhp+
http://www.rs2000-16v.co.uk/forum/to...TOPIC_ID=11148
You may need to sign up. Basically a guy off www.rs2000-16v.com has done a turbo'd I4 and its done right
CAr still needs finished, but the engine is running in it.
cheers lads for the help, i take it. its gonna be expensive to turbo it up then!,
How about supercharging or nitrous?, i can install most things myself, just getting things setup though!.
or i would like as close to 200bhp as possible, im also in 2 minds to cvh frst it, u see my rs2000 is a cossie rep, so i need so sort of turbo engine to finish it off!
Originally Posted by churchy
Whatever u do, you'll have to let me av a little look at it when I bump into ya (not literally) ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
