is there any difference in shells?
Old Nov 19, 2005 | 05:15 PM
Dunc Maclean's Avatar
Dunc Maclean
Default is there any difference in shells?
between a saphire cossie shell and a normal saphire shell?
Dunc
Old Nov 19, 2005 | 06:56 PM
cossiecrew's Avatar
cossiecrew
i think all 2wd are the same but not 100% someone knows the answer i think 4x4 shells are slighly different to a 2wd
Old Nov 20, 2005 | 08:34 PM
Dunc Maclean
cheers mate, anyone else help me out?
Dunc
Old Nov 20, 2005 | 08:37 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Dunc
the bulkhead is not the same on non abs sierra's
Old Nov 20, 2005 | 08:43 PM
foreigneRS's Avatar
foreigneRS
Testing the future
what are you planning?
don't forget also, that cossies had tinted glass, heated screen etc.
4x4 have a different panel in the floorpan, but all 4x4 are the same in that respect.
i've had differences in the bolt size on the front anti-roll-bar mounts before as well.
as martin said, non abs bulkheads are different.
sierra's with a/c also have a different bulkhead.
Old Nov 20, 2005 | 08:49 PM
mrviper's Avatar
mrviper
when i read the title i thought he meant the shells in the engine
Dunc Maclean
so, a normal 2wd saphire is pretty much the same as a 2wd cossie shell?
the reason i ask is just reshell purposes
Dunc
Old Nov 20, 2005 | 10:34 PM
cossiecrew's Avatar
cossiecrew
well it looks like as long as you get an abs model then yes
Old Nov 20, 2005 | 10:37 PM
Ginge !'s Avatar
Ginge !
just finding my feet
the 4wd has extra clearence on the inner wings for the front drive shafts
Old Nov 21, 2005 | 08:40 AM
Dunc Maclean
ahh well its a 2wd i'd be needing.
so what are the actual differences in the bulkhead between a abs model and a none abs model?
and did all saff cossies have abs?
Dunc
p.s. sorry for all the questions lol
Old Nov 21, 2005 | 09:07 AM
Daveyboy's Avatar
Daveyboy
saph cossies also had strengthened pillars iirc
Old Nov 21, 2005 | 09:39 AM
rstoughy's Avatar
rstoughy
AS above plus Foam filled pillars IIRC and holes under the rear seat for the ABS wires
Old Nov 21, 2005 | 09:45 AM
foreigneRS's Avatar
foreigneRS
Testing the future
all saph cossies did have abs, so it's better to get a donor that did have.
i have fitted abs to a non abs shell, but given the choice i would rather have the right shell.
your best bet, and i know this based on many reshells, is to either have a cossie shell (2wd or 4x4, doesn't really matter for a 2wd installation except for a length of 50mm box required to mount the gearbox x-member), or something like an xr or ghia model as these come with all the electrics already in the car for windows, mirrors, heated screen, abs etc, and with tinted glass.
good luck with the reshell.
Old Nov 21, 2005 | 10:18 AM
Stealth Bomber's Avatar
Stealth Bomber
Oh and if you're reshelling due to stacking your Saff, we want pics!!!
Old Nov 21, 2005 | 11:14 AM
Ratty's Avatar
Ratty
Dunc
What differences are there out of intrest, as I never noticed any when I converted my non abs lxi (the one in my sig btw)
Only thing I had to do to fit the ABS was drill 2 holes at the back for the wiring loom to go through under the seat
Old Nov 21, 2005 | 11:50 AM
foreigneRS's Avatar
foreigneRS
Testing the future
iirc, and it was about 5 years ago now that i put abs into an old 3 door 1.6 l shell, it needed a couple of extra holes for the pedal box, and maybe a bigger hole for the actuating rod? i think it should have a strengthening plate as well?
Old Nov 21, 2005 | 12:02 PM
foreigneRS's Avatar
foreigneRS
Testing the future
neither my 2wd or 4x4 shells (both genuine) had this.
Old Nov 21, 2005 | 12:11 PM
jonnyturbo's Avatar
jonnyturbo
is the gearbox cradle mounts not different for the cossies to standard sierras?
bobsworth
77
Mar 24, 2016 09:30 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Fil
Sep 30, 2015 12:08 PM
SMILER258
Sep 28, 2015 09:04 AM
