FAO ANYONE reagarding a fuel pump for cossie for tomorrow
Testing the future
they normally die when they get shit in them. and cos of their design it only takes a tiny bit of something to lock the pump up. so before you put another one on and have the same problem, check the pre pump filter ffs.
you can dismantle the pumps and take the obstruction out if you're careful and skilful - unlikely, you being welsh and all
if the seals arent kept submerged in fuel then can go hard n crack, so using pumps that were good when removed often die when fitting to another car...
best to buy pumps new imho
Testing the future
wrong, sierra's have, or definitely should have a pre pump in-line filter as well as the large post pump filter.
if your mates hasn't then no wonder he keeps going through pumps. it is a small mesh that is part of the pre-pump fittings.
fit one or keep breaking expensive pumps, your choice.
laugh and ignore me if you want, not my problem.
ForiegnRS=Unless there is a prefilter either in the tank or in the pump itself .There is defiantly NO prefilter b4 pump On a 3dr sierra like the 1 were talking about or MINE.There is a pipe that goes straight from tank to pump and thats it.
Testing the future
whatever.
i've seen it with my own eyes. and i've seen how a tiny piece of metal less than 0.5mm square can block the pump. if you run without a prefilter you can expect it will happen sooner or later. even if there isn't one as standard, i would fit one.
that's my final word on it. do what you like.
Dont start giving me the rolleyes.
I understand your point about it being a good idea. BUT i was just stating that as standard they dont come with one.
Okey Dokey.
Okey Dokey.
Originally Posted by Ryan
send me a txt on 07919537128 if you need me to bring it mate.
cheers
Ryan
cheers
Ryan
cheers dude
can u take it, just in case and i'll pk to you tomorrow as to wether he needs it or not
he thinks he has 2, but not sure
kosienutter
31
22-08-2015 09:55 AM
CabrioTurbo
01-08-2015 11:04 AM
