What 5w-30 for your Zetec engine - guidance
I had a long discussion recently with the tecnical guys from a large oil company about Ford Spec 5w-30 oils.
These oils are fuel economy oils normally meeting FORD WSS-M2C913A/B.
The standard (cheaper) oils are always ACEA A1 which are designed to shear in use (lose viscosity) which is fine for a normal unmodded road car.
The problem is, if your car is modded or driven hard, these oils become very thin within 5000 miles!
I have been strongly recommended to advise people that if your car is not a stock road car then you should not use these oils.
In this case you should use a 5w-30 which carries ACEA A3 or A5 as these oils are superior quality and do not shear (lose viscosity) as easily in service.
The consequence of not doing this is severely shortened engine life!
ACEA SPECS
A1 Fuel economy petrol
A2 Standard performance level
A3 High performance and/or extended drain
A4 Reserved for future use in certain direct injection engines
A5 Combines A1 fuel economy with A3 performance
Just thought this would be of interest.
Simon
ACEA SPECS
Simon
This ACEA A5 5w-30 is a good synthetic (I use it in my RX8)
http://www.opieoils.co.uk/TechSpecs/...5W-30_8123.pdf
Or.......................
The dogs danglies of 5w-30's
http://www.opieoils.co.uk/TechSpecs/...r%20Racing.pdf
Don't expect to pay Ford's ACEA A1 prices though!
Simon
Simon
My 1.8 zetec normally gets gtx magnatec 5-30w in it, now its now high power like some on here (144bhp) but what would you recommend to use for it
Steve
Steve
Castrol Magnatec is a basic ACEA A1 oil, see the listing above.
I would use the Motul 8100 5w-30 A5 oil, much better in service for staying in grade as it's a performance oil. (I use this in my 230bhp RX8)
Simon
Simon
It's very new and incorporates the API SM specs so it's a rebadging exercise on the old RS oils which are still available. Early days.
Simon
Simon
I have a Focus ST170 which is totaly standard (apart from K+N filter) would you recommend swtching from the std ford 5w-30 oil that they change when its sservice at fords?
I do drive it high in the rev range when having a bit of fun wih it, would a better oil protect it better at high revs?
Simon
Simon
JoeyBoyden
04-01-2024 02:36 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
