Problem!!
Old Oct 31, 2005 | 05:54 PM
B11GNS's Avatar
B11GNS
Default Problem!!
The bolt has sheared flush, i drilled out a hole in the middle then used an easy out but the easy out snapped in there (shit pic i know!!) anyone got any ideas on how to get it out?
Old Oct 31, 2005 | 06:01 PM
boXXer's Avatar
boXXer
GASH!
pillar drill, and a fooking hard bit to go in it. Had the same problem with mine. You could also try to drill small holes all around the outside and get it out that way. Must say, looks VERY familiar and its VERY frustrating
Old Oct 31, 2005 | 06:27 PM
THEYGOTMETOO's Avatar
THEYGOTMETOO
CUNT!
From: BLUE PILL or RED PILL ... All I offer is the truth, nothing more, nothing less. You choose.
Milling machine with a solid carbide end mill will machine the stud out without any problems. You could use a pillar drill but you'll need to use split collets with the end mill as a jacobs chuck will not grip the end mill's shaft correctly.
Either that or, I would personally try the easiest thing first: Weld a washer to the stud then weld a nut on top of the washer, then use the nut to try and undo the remains of the bolt
Famous last words but it should be pretty quick and easy job
Old Oct 31, 2005 | 06:33 PM
Tony Ryan's Avatar
Tony Ryan
These are titanium bolts !! thats why theyre so expensive , unless someone has fitted a std bolt and thats why its snapped ??
Old Oct 31, 2005 | 06:35 PM
carl_harker's Avatar
carl_harker
easi outs may be easier to shatter. use a centre punch and hammer good luck!
nthorpey's Avatar
nthorpey
Take it to see foreman in machine shop and ask him very nicely to put it onto the spark eroder If you get really stuck steve give me a shout and i'll see what i can do for ya. how you keeping anyway, see you go past me a week or so ago on the A130 about 6.45am towards bas. car looked and sounded sweet
Old Oct 31, 2005 | 06:36 PM
boXXer's Avatar
boXXer
GASH!
the ford ones are CRAP imo, i think i broke 3 out of 4 when removing them.
Old Oct 31, 2005 | 06:38 PM
GARETH T's Avatar
GARETH T
come on,, you know nothing ever goes too plan in engineering
Old Oct 31, 2005 | 06:52 PM
abdr500's Avatar
abdr500
why no dril it out and put a nut and bolt through it
Old Oct 31, 2005 | 07:04 PM
B11GNS's Avatar
B11GNS
Originally Posted by nthorpey
Take it to see foreman in machine shop and ask him very nicely to put it onto the spark eroder If you get really stuck Steve give me a shout and i'll see what i can do for ya. how you keeping anyway, see you go past me a week or so ago on the A130 about 6.45am towards bas. car looked and sounded sweet
Will try that, cheers Nick
Yeah im keeping good, you?
Was on my way back from Ipswich when you saw me, on way to work.
Old Oct 31, 2005 | 07:06 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Richpon has a 2wd manifold for sale, make him an offer ....
Look in cossie parts for sale steve
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
