Peeps who know about guitars?
what are the ones called that have that little stick that moves in and out, tremelo?
Are they hard to play? would love to have a go, there well cool
erm... i'm a guitarist since 12 years, but can't figure out what you are speaking about.
The part you are speaking about is called a "tremolo" (not tremelo ) and the best types of trems are Floyd Rose ones, found on lots of brands of guitars.
and yes, a guitar is hard to play. you won't be able to catch one and rock immediatly LOL
Maybe you thought "tremolo" was a brand of guitar, but it's not... it's just a part of every guitar
a tremolo is floating. Guitar strings pull it from above, while some springs pull it from under. The result is that it's floating and allows to put or remove tension on the guitar strings when you push or pull on it, creating this funny sound you seem to like
and to finish, some pics of my main guitars
if you have some questions, PM me
Last 2 guitars have 7 strings instead of 6, in case it interests you.
Cheers mate, very informative
And yeah i did know the tremolo was part of the guitar and not an actual make of guitar! just wanted someone to confirm that was the name of the part!
How much harder are these to play than one without a tremolo then?
mmmmmh... well, if you use trem a lot, yes it's harder, you can say. But using it from time to time does not make playing more difficult. What's a lot worse with a tremolo is tuning... as it's floating, each time you tighten a string, the 5 others lose tension, if you see what i mean... which makes tuning a pain if you're not used to
what can be a bit harder too at first is that when you play, your right hand may push accidentaly on the trem body, causing fluctuations in the tonality of the note... causing the music sounding wrong
but again, this is just something you get used too... arrange yourself to rest your palm somewhere else than on the trem body
pic of mine... well ones like mine nicked off the net!
I also have a jap squire with a reverse headstock and floyd rose trem in candy apple red with a black strach plate.
My amp is a Marshall JTM30
Alex
Alex
yep, the two white ones are Steve Vai models (one 6 string and one 7 string)
The first multicolor one is a John Petrucci model (my all time favourite guitar, and i owned quite a lot of different brands and sorts )
The last grey one is a RG series 7 strings
Imaloverofcars -> it's a good example there... the guitar he just posted (it's an Epiphone SG special) does not have a floyd rose trem, as you can see the bridge on this one is fixed
My amp is a Mesa Boogie dual rectifier
Here is it :
Here is it :
paceo
25-09-2015 08:05 PM
paceo
17-09-2015 12:12 PM
