Help Needed - S2 Running Problem...
Old Oct 14, 2005 | 02:01 PM
Ben's Avatar
Ben
Default Help Needed - S2 Running Problem...
Having problems getting my S2 to run. Following an extensive rebuild the car does start, idles about 1500 rpm for a few seconds and then dies. I can drive the car if I keep the revs up but otherwise it just stalls.
I've checked all the obvious causes but to no avail. The only pipe that is not connected is from the oil breather to under the metering unit - would this cause the problem I'm experiencing? If so I need to get a pipe to fit but was under the impresion this wasn't too importnat? Any other items worth checking as I'm at a loss and not sure what to check next.
Thanks guys!
Old Oct 14, 2005 | 02:38 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
if it has a standard breather system the all breather hoses MUST be connected, especially to themetering head or the car will not run/properly as the engine works off vacum.
Old Oct 14, 2005 | 02:46 PM
Stu @ M Developments's Avatar
PassionFords Creator
As Above. Put the car back together before you expect it work
Old Oct 14, 2005 | 02:49 PM
Ben's Avatar
Ben
Sorry fellas, meant to mention it's got a Bailey Oil breather...
Old Oct 14, 2005 | 03:03 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Ben - put a blanking plug in the metering head oil pipe hole and all your problems will be gone
untill next time
Old Oct 14, 2005 | 03:07 PM
Ben's Avatar
Ben
untill next time
Running out of 'next times' mate, won't be many things to change before long!!!!
Thanks for the advice, will give it a go tomorrow!
Old Oct 14, 2005 | 03:18 PM
vroooom ptssssh
It Wasnt Me!
ignore
Old Oct 17, 2005 | 09:10 AM
Ben's Avatar
Ben
Had a go at blanking the metering head oil return hole and it hasn't made any difference.
I've noticed that the car does start from cold although it is mis-firing (it's got new plugs and leads). After a few seconds it then stalls and won't start again.
Checked and double checked that I've put everything back together properly and everything seems fine. The only thing I'm thinking could need looking at is the mixture. Is this something I could adjust to get the car running again and then get it looked at by a pro?
Also, any other pointers as to what I should be checking given the symptoms described previously?
mk22door
49
Mar 26, 2022 07:15 AM
big_Rad
Sep 15, 2017 09:36 AM
kosienutter
31
Aug 22, 2015 09:55 AM
Aug 8, 2015 07:12 AM
col93saphcos
Aug 7, 2015 03:21 PM
