Installing SATA drive help!
Old Oct 3, 2005 | 10:28 AM
SimonT's Avatar
SimonT
Default Installing SATA drive help!
I bought myself a PCI sata card and a 200gb hard disc for my little w2k box that acts as a storage machine.
Anyhoo, all parts in, drivers installed. no conflicts. Lovley stuff....
I cant seem to get windows to see the disk.
I cant seem to get passed this stage in disk managment:
anyone give me any tips?
ta
ST
Old Oct 3, 2005 | 10:29 AM
Ish's Avatar
Ish
have you formatted the sata h.d?
Old Oct 3, 2005 | 10:31 AM
Stealth Bomber's Avatar
Stealth Bomber
What makes Sata any different from the normal ones??
Old Oct 3, 2005 | 10:32 AM
SimonT's Avatar
SimonT
no. I cant get the operating to see the disk as a drive (IE A: C: D: E: etc) but shows up in disk mangment and I cant seem to find anyway to "activate" the drive so windows see's it as a logical device.
Old Oct 3, 2005 | 10:34 AM
DanRSturbo's Avatar
DanRSturbo
That's because there is no partition on the drive, and it's not been formatted. To do this, right click on the drive, and it should say "create partition", it will ask you what file system you want on it, (fat, fat32 ntfs etc, etc) and then the size of the disk you want to use. Once that's done, right click the drive again and choose format, again it will ask you about the file system and then the size of the disk you want to format. Should take no longer then 30 misn or so to do it
Old Oct 3, 2005 | 10:36 AM
Ish's Avatar
Ish
When i built my new pc with an sata drive when i tried to install xp it couldn't see any drive. I had to take the sata driver off the mobo cd and use that for xp to see the sata drive. Dunno if this is relevant in your case though
Old Oct 3, 2005 | 10:37 AM
SimonT's Avatar
SimonT
Cheers dan I'm such a cunt! I stupidly closed the "new disk wizzard"
and I work in IT
Job's a gooden now though!
Old Oct 3, 2005 | 10:39 AM
Ish's Avatar
Ish
main difference is that it is supposed to be a quicker transfer rate than IDE but i didn't really notice any difference
Old Oct 3, 2005 | 11:01 AM
DanRSturbo's Avatar
DanRSturbo
SATA drives are supposed to have a quicker transfer rate then IDE, and using a sata drive free's up your IDE channels on your board, as standard, your limited to 4 ide devices, my work one for instance has 2 hard drives, and 2 cd drives, my home system has 5 hard drives and 2 cd drives as I have a maxtor PCI IDE controller, which has 2 channels on it, allowing another 4 drives if need be
Old Oct 3, 2005 | 11:47 AM
JohnnyB's Avatar
JohnnyB
Dear Dear Me
Becka674
11
Oct 8, 2015 03:11 PM
Fiddy
21
Sep 29, 2015 06:10 PM
A.t.p
Sep 29, 2015 05:04 PM
IainRS1700T
Sep 25, 2015 06:44 AM
tib2220
Sep 14, 2015 12:33 PM
