Cossie ECU/2stage boost question..
I remeber people saying about cutting into a wire in the ECU to split boost,EG,a 2 stage boost...
What wire was it kiddys,and did/does it work???
Pete...
Pete...
Can't remember pin number, but you can do it on the amal valve wiring also( if still used). Hi-low boost then depends on the way the amal is jetted.
Tiff, that reminds - have to do something for Little Joe
..yes this is the amal valve wiring!!!
Find the valve it has 2 wires going to it,cut into either wire and put a switch in ...drops appox 6 psi on lo boost.
(assuming you is using the amal valve!)
PMSL @ Tiff
I know mate, but the truth is that the 370bhp 3DR really does scare me. I dont like it when the rear wheels spin up and i have no control over the car.
I really am scared of it and i think i should really stick to Vauxhall Novas, as they are "SAFE"
Sheet! Didn't realise you had that much Pete, you're doing the right thing imo. At the risk of looking like I keep going on about my car mine's 4wd but I've got variable boost knob - better safe than sorry, and my missus sometimes uses the car.
TIFF YOU COCK SUCKING,DOG SHAGGIN,4X4 DRIVING,KIDDY TOUCHING MOTHER FUCKER!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Mess with me posts again,and il chop ya fingers off!!!!!
Pete.....
Pete.....
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
