Cam pulley differences
Old Jul 3, 2004 | 08:58 PM
Rick's Avatar
Rick
Default Cam pulley differences
On the CVH, whats the diff between KA, LA etc
Old Jul 4, 2004 | 09:12 AM
Rick's Avatar
Rick
up
Old Jul 4, 2004 | 09:24 AM
GARETH T's Avatar
GARETH T
havent a clue
Old Jul 4, 2004 | 12:36 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
Different pulleys for different engines and different timing. In short
Old Jul 4, 2004 | 12:51 PM
M Brian's Avatar
M Brian
I think karl has the details on the exact differences.
KA is the RS Turbo one I think. Theres KA, LA and AA
you trying to get out of using a adjustable pulley?
Old Jul 4, 2004 | 12:54 PM
GARETH T's Avatar
GARETH T
in another words you dont know
i could of guessed that
Old Jul 4, 2004 | 01:16 PM
Versus_Creations
Ask me a question!
What you talking about?
I just told ya that the pulleys are from different cars, for this reason the cam needs different pulleys to set the amount of time valves will be open closed etc... If you put the pulleys on top of each other the amount of teeth/spacing will change between them.
E.g 1.4cvh / 1.6cvh etc... are different
If you want the timming figures for the pulleys ill get them for you.
It was better than your reply
havent a clue
Infact what was the point of your reply
Old Jul 4, 2004 | 01:23 PM
GARETH T's Avatar
GARETH T
i think that is what he wanted
about as productive as yours
Old Jul 4, 2004 | 05:53 PM
Rick's Avatar
Rick
LOL - no shit they're diff.....
I know KA is the RST one, ive got an LA as well. Im running her in on a new std cam, Karl will be making me a cam when i fit the big turbo - i'll get a vernier then.
Wanted to know the exact differences as it's hard to tell visually.
Old Jul 4, 2004 | 06:09 PM
Ginge !'s Avatar
Ginge !
just finding my feet
will be the cam timing as the head and cams are the same as a xr3i i would have thought
but im not a top tuner or a pirate of other peoples hard work so i dont know for sure
cheack and see if the main difference is a oddkid etching on one of em
Old Jul 4, 2004 | 06:19 PM
M Brian's Avatar
M Brian
[jano mode] There are two big letters stamped into them [/jano mode]
if i can remember rightly each tooth was about 4 degrees crankshaft timing.
so its understandable that its hard to spot a degree or two difference in them.
can you not get it accurate enough with a rule, mark the quadrants and see where the most vertical tooth is in relation to the keyway?
EDIT - that is just incase jano doesnt come back with the detail differences.
Old Jul 4, 2004 | 07:06 PM
Rick's Avatar
Rick
Melv - I could...... but i'm not gonna....
Old Jul 5, 2004 | 08:45 AM
JesseT's Avatar
JesseT
Counting from a crappy picture the pulley has 38 teeth. This would make the crank pulley have 19 teeth. This would make each cam pulley tooth result is 19 degrees of crank timing! Comparing a KA (rst) and a AA (1.6 efi) cam pulley, they are already nearly half a tooth apart in timing. This is MUCH. If someone has the exact figures, I 'd like to see them.
Nov 1, 2015 06:53 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
