I-Pod users - in car help required...........
Old Sep 29, 2005 | 07:12 PM
RichardPON's Avatar
RichardPON
Default I-Pod users - in car help required...........
Is there any way of doing the following?
Running a lead from the headphone port of the I-Pod to an RCA on the back of the headunit and using the AUX channel to play?
I've tried it, but can't find any settings to change to let the head unit know of the input.
Head unit is an Alpine9812.
Anyone else done anything similar?
Old Sep 29, 2005 | 08:06 PM
Billy C's Avatar
Billy C
Just get the alpine hub, model xxx 420 something.
I got the alpine 9815 and it controls the ipod thru the head unit.
Old Sep 29, 2005 | 08:22 PM
TIFF's Avatar
TIFF
Chasing Radders
Can you not get one of those radio tuner things
Converts your I-POD to basically a radio broadcast, Then you tune your Stereo into that channel and hey presto
Old Sep 29, 2005 | 08:23 PM
Cossie Helen's Avatar
Cossie Helen
I got one of those, mine works really well
Old Sep 29, 2005 | 08:28 PM
Oranoco's Avatar
Oranoco
FM modulator
Old Sep 29, 2005 | 08:30 PM
RS2000CUSTOM's Avatar
RS2000CUSTOM
Try this
http://cgi.ebay.co.uk/i-Trip-mini-FM...QQcmdZViewItem
Old Sep 29, 2005 | 08:31 PM
RS2000CUSTOM
But I cant get it to work in my MKII RS2000
Have tried all the stations/frequencies available
On both MW and LW - lol lol lol
Old Sep 29, 2005 | 08:44 PM
Chrissy_bwoy's Avatar
Chrissy_bwoy
rich,
if you go into the menu section of the headunit, it should allow you to turn aux on/off altho i think with it on it doesnt allow the cd changer (if you have one) to work.
i dont think the new alpine adaptor works with the 9812, i may be wrong tho
HTH
Old Sep 29, 2005 | 08:45 PM
N8THN's Avatar
N8THN
My bro has asked the question for me - Its my iPod we're trying to fit.
A friend of mine had his ipod connected to the back of his stereo using an RCA to ipod connector (the connector at the bottom of the ipod). He bought it from Maplin for Ł5. Only down side is it doesn't charge the ipod, but for Ł5, you cant expect miracles. Music quality is spot on.
I am now trying the same thing but have used an RCA to headphone socket and plugged it into the headphone slot on the ipod - This should work using the auxilary mode on my Alpine.
When I put the Alpine to Aux mode, you can really faintly hear the music when turned to full volume. I have seen this work so think it must be a configaration problem with the Aux input. Any ideas???
Trying to save splashing out the Ł60 for the module and didn't want to use the FM iTrip, as have had problems in the past.
Cheers so far though guys!!!
Old Sep 29, 2005 | 09:05 PM
N8THN's Avatar
N8THN
if only it was that simple
Old Sep 30, 2005 | 12:23 AM
CozzyBrom's Avatar
CozzyBrom
just get the fm thing load easyer
and it had a car charger
Old Sep 30, 2005 | 12:59 AM
Al Bags's Avatar
Al Bags
The outputs by a lot of the newer devices (through the headphone pre-amp) is
reduced ... maybe to stop kids blowing their brains out with normal volume)
Best with the proper adapter mate. They come up on eBay.
Old Sep 30, 2005 | 01:29 AM
saff_cossie's Avatar
saff_cossie
There are a few ways of getting the audio in to the car stereo. Easiest is some form of FM transmitter, either the FM Modulator or Belkin Tunecast or one of the others on the market. They are also the cheapest.
An option here a friend does with his WRX is he sits the ipod in a dock behind the gear stick and runs a cable into the FM input on the back of the head unit which has a splitter so he can put his normal FM input in as well. That is very good but like someone has said above, doesnt charge the iPod.
The best one that I have seen is:
http://www.mp3yourcar.com/
Only available in the US from what I have seen and does use the changer input on the back of the headunit.
HTH
Old Sep 30, 2005 | 09:04 AM
Porkie's Avatar
Porkie
Rich, I tried loads of things then gave up and now just put headphones in
Old Sep 30, 2005 | 09:37 AM
CozzyBrom's Avatar
CozzyBrom
the fm thing comes with a fag lighter lead to charge it up
and a fully charged ipod will last 6hrs anyway
Old Sep 30, 2005 | 09:44 AM
Porkie's Avatar
Porkie
Those are the ones that Sean sorted all his 'mates' out with....
Ginger Knooooobbbbber
Old Sep 30, 2005 | 10:29 AM
RichardPON's Avatar
RichardPON
Cheers guys - will pass the info on to my brother.
Old Sep 30, 2005 | 11:21 AM
James2wd's Avatar
James2wd
I've got an Itrip and the sound quality you get on it is shit tbh, no where near cd quality.
Old Sep 30, 2005 | 12:10 PM
N8THN's Avatar
N8THN
Cheers for all of your replies guys.
I have now found out that for the Alpine units like mine - Alpine 9812, the 2 RCA's on the back of the unit are both outputs and the only way to use the auxilary channel that the unit has is by connecting an Alpine KCA 121B lead that turns your CD changer port into an RCA input.
Therefore you can have 2 RCA outputs and 1 RCA input but not at the same time as having a CD changer connected. The Aux channel will then work.
The lead is about Ł12. http://www.incarexpress.co.uk/view_p...partno=KCA121B
Therefore options are Ł12 for a lead (KCA121B) to use the ipod in the car, or Ł65 for the box of tricks (Alpine KCA-420i) that allows you to use your headunit to operate the ipod (therefore no need to ever have the ipod out of the glove box) and charge it at the same time.
Think it's got to be the Ł65 job.
Cheers though!
Old Sep 30, 2005 | 01:51 PM
CraigN's Avatar
CraigN
i have the KCA 420i its not that good unless you haved a top of the range alpine unit as the screen doesnt display enough.
mines a 9835r works a treat
Old Sep 30, 2005 | 03:34 PM
rsdene's Avatar
rsdene
u want one of these, only a penny works a treat got from china in 7 days too
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWN%3AIT&rd=1
Old Sep 30, 2005 | 04:49 PM
Al Bags's Avatar
Al Bags
Craig ... How do you find that 9835? I am going to get a 9855 iPod ready one shortly (fancy that slide bar thingy!)
Cheers ....
TIL13R
11
Aug 13, 2015 02:28 PM
track.focus'd
Aug 12, 2015 05:53 PM
slammedorion
21
Aug 6, 2015 11:38 AM
vdubo7
Aug 2, 2015 08:17 PM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
