building regs - help advice
Old 26-09-2005 | 01:55 PM
M Brian's Avatar
M Brian
Default building regs - help advice
i've removed a studded wall in my bathroom to make it one room instead of a separate WC and bathroom.
Im selling my house and a query has been raised by the buyers solictor asking if the removal of the studded partition required building regulation or planning permission.
now it was none load bearing flimsy as fook - next doors is gone?
any idaes if I needed planning etc?
Old 26-09-2005 | 02:30 PM
Hayxr's Avatar
Hayxr
Me mum n dad done that to one of our old house's they didn't need any planning permission!
I'm almost sure you won't need to get any planning permission unless you are affecting an outside wall!
Old 26-09-2005 | 02:38 PM
Chris Honeywell's Avatar
Chris Honeywell
you will not need building regs but most likely you will have to get the building regs people write you a letter saying that building regs is not needed
we had to do something similar with our conservatory...
After we got the letter and sent it off to the sols we then had to go back and get aletter saying we did not need planning permission
Old 26-09-2005 | 04:56 PM
M Brian's Avatar
M Brian
who are the building regs people?
what chance have I got of getting this sorted and through quickly?
Old 26-09-2005 | 06:56 PM
st3v3's Avatar
st3v3
your local council office will have a planning dept some where,that who you need to see,well thats where i got all mine sorted for my extension and garage conversion
Old 26-09-2005 | 07:37 PM
joel_winders's Avatar
joel_winders
if it's non load bearing it should be A ok !
Old 26-09-2005 | 08:53 PM
EIL132's Avatar
EIL132
If it's a simple wooden partition then no
Old 26-09-2005 | 09:27 PM
Little Joe's Avatar
Little Joe
Best thing to do if your are not 100% sure is to give your local council office a call.
Old 26-09-2005 | 09:28 PM
EIL132's Avatar
EIL132
That's where I work, well building control and that's where you want to ask if anywhere
Old 26-09-2005 | 11:00 PM
Lee Reynolds's Avatar
Lee Reynolds
as james says contact building control, they will likely check it out and give you a letter of confirmation.
This is why you should always get building control to oversee any DIY work like removing walls you do as it makes less hassle later on when selling. Even if its only a stud wall, building control will give you a scrap of paper saying so for you to keep till ya in this situ
costs ya but saves ya if ya get me!
Old 27-09-2005 | 09:06 AM
M Brian's Avatar
M Brian
am I now going to get trouble doing it retrospectively?
it was only a simple studded wall. it nearly fell down on its own pmsl
what sort of cost is it to get building control or whoever to have a look?
Old 27-09-2005 | 09:13 AM
Hayxr's Avatar
Hayxr
we never had any problems with ours! New owners didn't even question it!
Just go down to ya local council babe and see what they say! May be different up your way as your all weird pmsl!
Old 27-09-2005 | 10:04 AM
M Brian's Avatar
M Brian
nico12
31-12-2015 05:42 PM
DanDMC
33
07-10-2015 02:58 PM
IainRS1700T
25-09-2015 07:44 AM
gambo08
Fiesta RS1800/RS Turbo
16-09-2015 09:10 PM
CrOwSoN15
14-09-2015 12:33 PM
