Fun with turbos :D
Old 24-09-2005, 05:03 PM
dumped
dumped's Avatar
Default Fun with turbos :D
As you know this is my little twin turbo saff coco
The 2nd turbo is a little shy so dont scare it off lol
Just incase some of you thought it wasnt a "twin" setup. You can actually see it in the top pic spinning away quite merily Full boost by 4k on a standard low comp cossie lump..... turbos are funny things
Old 24-09-2005, 05:05 PM
Stu @ M Developments
PassionFords Creator
Stu @ M Developments's Avatar
Old 24-09-2005, 05:06 PM
adamS2RST
adamS2RST's Avatar
jeez
Old 24-09-2005, 05:07 PM
Nicole
Nicole's Avatar
That looks pretty serious
Old 24-09-2005, 05:08 PM
AJ Escos
AJ Escos's Avatar
you sure that turbo is big enough
does look impressive though
Old 24-09-2005, 05:09 PM
Oranoco
Oranoco's Avatar
What the fuck is that turbo off? A train!!!!!!
Stealth Bomber
Stealth Bomber's Avatar
I don't understand it, but I WANT that engine
Old 24-09-2005, 05:10 PM
dumped
dumped's Avatar
The boys at the garage said it was to make up for my manhood.... how did they know ?!?!?!?! Going to get my Gf to beat then up though...she has the balls in our relationship! lol
Old 24-09-2005, 05:12 PM
Stealth Bomber
Just out of interest, where is turbo 1 and where is turbo 2, I can only see one in the engine pic.
Old 24-09-2005, 05:13 PM
Rhys
Rhys's Avatar
That turbo is bigger than the engine! lol No way is that going on!?
Old 24-09-2005, 05:14 PM
Andy-R
Andy-R's Avatar
Old 24-09-2005, 05:15 PM
AJ Escos
AJ Escos's Avatar
the first turbo is the one you see which is the smaller of the two, the second one is just visible between the inlet plenum and the link pipe, you can see the pipe curves down to the second turbo HTH
dumped
dumped's Avatar
Rhys - look at the top pic - it has been on for ages! lol
* hint - look for the missing steering pump
Old 24-09-2005, 05:16 PM
Stealth Bomber
Yeah sure I see it now, wouldn't mind a pic from the other direction to get a better idea of the pipework tho
Old 24-09-2005, 05:18 PM
Rhys
Rhys's Avatar
Martin Fair play.
So when we going to see some figuers for this beast then? Or she shy to the attention?
Old 24-09-2005, 05:20 PM
dumped
dumped's Avatar
Its just a standard 2wd engine at the mo with skimmed pistons - made it out of other peoples misfortunes lying around the workshop lol - no joke - that IS the spec Just to get it all running and see what falls off
Old 24-09-2005, 05:25 PM
Daviet
Daviet's Avatar
is there any room for a bigger one
would still be good to see figures even if it is a standard engine more or less
Old 24-09-2005, 05:34 PM
M.A.D.RST
M.A.D.RST's Avatar
Thats huge, fair play!
But why go for twin turbos? Thought most people on here said it wasnt necessary!!?
Old 24-09-2005, 05:39 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
MAD RST- Its not twin turbo how youd know it, its a bit "special"
Dumped- This is proper turbo blowing into turbo compound charging right?
how big is the thumper just out of interest?
T106?
Old 24-09-2005, 05:40 PM
Andy-R
Andy-R's Avatar
The mans a nutter and is having a laugh building it! Its all a bit of fun
Old 24-09-2005, 05:44 PM
Neil
Neil's Avatar
the 2nd ones a baby
when go to work will take picture of the one's in work next to to 12 inch ruler after bank holiday
this produces 2500 bhp at 1800 rpm on 2 of them
Old 24-09-2005, 05:49 PM
dumped
dumped's Avatar
Its just a bit of fun so why not means you can run insane boost if the mood takes you eg -
going to shops - 15 psi more than adequate
rushing home left the iron on - 30psi should do the job
clearing head after fight with the other half - 45 psi recommended
start/finish straight nat day 2006..... 60 psi expected roflol!
turbo system will do it all day... intercooler and block may have slight objections lol.... trial and error etc etc lol
Steve - its just a weiner 88 lol and is proper staged fun.
Old 24-09-2005, 05:51 PM
dumped
dumped's Avatar
ok neil - make then work on your dohc 2.0 then put em up lol
Old 24-09-2005, 05:54 PM
Neil
Neil's Avatar
i'd never get it onto boost i'm afraid
but the engine uses 55 gallon of fuel in an hour running flat out fully loaded
Old 24-09-2005, 05:55 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
proper staged turbos kick ass, but ive NEVER seen it on a petrol car until now
Awesome
A Y2K T88 like that is good for well over 1000bhp so cant really complaoin eh
Old 24-09-2005, 07:26 PM
Rick
Rick's Avatar
Thats damn awesome.
Old 24-09-2005, 07:35 PM
warleydaddy
warleydaddy's Avatar
Bet you could boot it in Easter,and it wil spool up by xmas!!!!!!!!
Pete...
Old 24-09-2005, 08:47 PM
The DIVA
The DIVA's Avatar
So you've upgraded the 204 ponies to Stage 1 now
Old 25-09-2005, 12:41 AM
fitzy_88
fitzy_88's Avatar
how does compound turbocharging work?
does the pressurised air from turbo one enter the inlet of turbo two?
i think i can see how it works from that picture - does the exhaust gas retain enough velocity to spin up the two turbos? and what sort of performace does this produce? mega boost?? anyone know anything about this or where i could find out more info cause i've had a look on the net and cant find hee haw...
thanks in advance...
Euan
Old 25-09-2005, 01:14 AM
Physio
Physio's Avatar
Pete...
Exactly!
Old 25-09-2005, 08:44 AM
cossy abuser
cossy abuser's Avatar
what size intercooler, Not Standard Surely?
Not with the colour of the manifold
Old 25-09-2005, 08:55 AM
AlexF
AlexF's Avatar
wow!!
MORE PICS RIGHT NOW
(please)
Old 25-09-2005, 08:58 AM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
Originally Posted by J871yhk
wow!!
MORE PICS RIGHT NOW
(please)
AGREED
Old 25-09-2005, 09:25 AM
bud-weis
Football Cwazy
bud-weis's Avatar
couple more here
https://passionford.com/forum/viewto...light=standard
Old 25-09-2005, 10:03 AM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Pete...
Exactly!
should have no more lag than if it was the T4 on its own, maybe slightly less
Old 25-09-2005, 10:05 AM
Paul Eggleton
Paul Eggleton's Avatar
Nutter
Old 25-09-2005, 03:17 PM
dumped
dumped's Avatar
charge temp was 22 degrees flat out on the rollers, bit less on the road - no its not too standard lol
Matched against mike rainbirds T4 graph it does indeed have less lag And still not fully optimised - we expect better.
Old 25-09-2005, 03:21 PM
Stoo
Stoo's Avatar
pmsl i've seen the intercooler!
Quick Reply: Fun with turbos :D
