driveshaft help needed please
Old Sep 24, 2005 | 12:49 PM
cozzymatt's Avatar
cozzymatt
Default driveshaft help needed please
hi people,
the o/s/f driveshaft gave up on my escos today i have removed the outer from the hub but i am really struggling getting the other end out.. is there a special way to do this ? and what is the notched section around the outside of the shaft that has a 13mm bolt holding it in place?
please help this is doing my head in
Matt..
Old Sep 24, 2005 | 12:57 PM
privatepie's Avatar
privatepie
duno about a cossie but on most cars ya just have 2 lever the fuckers out or use a slide hammer
Old Sep 24, 2005 | 01:10 PM
Danny boy's Avatar
Danny boy
you will have to drop the plate off the diff mate as there is a sirclip inside the diff which holds the inner joint in just make sure you have a bucket handy to catch the diff oil.
hope this helps
Old Sep 24, 2005 | 01:41 PM
St3V3_C's Avatar
St3V3_C
hope this helps
A lot of people don't bother putting that circlip back on either - up to you.
Old Sep 24, 2005 | 01:55 PM
cozzymatt's Avatar
cozzymatt
cheers mate big help
got the shaft out now
How much play if any should be in the front diff ? i know there is gonna be some because the shaft is out but even if you put pressure on that side of it there is still play there!
is it advisable to put the circlip back in ?
sorry for all the dumb questions but i feel a bit out of my deapth on a 4x4, i'm used to fwd...
Thanks for all help given it's very appreciated..
Matt
Old Sep 24, 2005 | 01:57 PM
Stu @ M Developments's Avatar
PassionFords Creator
You can leave the clip out without any dramas pal.
Old Sep 24, 2005 | 02:10 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
why do they put one in in the first place?
Old Sep 24, 2005 | 02:14 PM
cozzymatt's Avatar
cozzymatt
oh yeah how much oil do i need to put back in the diff... and whats the best stuff??
Old Sep 24, 2005 | 02:38 PM
Dean Saff's Avatar
Dean Saff
Thank good you didn't try this eh...
Old Sep 24, 2005 | 04:55 PM
silky16v's Avatar
silky16v
Get on That!
While your at it make sure the OSF Rubber Engine Mount isn't fuked this causes the shaft to move about more than it should thus destroying the CV joint
Chas
Sep 21, 2015 08:57 PM
matman
Sep 9, 2015 05:45 PM
markk
18
Aug 17, 2015 05:19 AM
col93saphcos
Aug 7, 2015 03:21 PM
Old ford
Jul 31, 2015 06:50 AM
