CPS problem, a little help needed please.
Old Sep 23, 2005 | 11:46 AM
EvilFranky's Avatar
EvilFranky
Default CPS problem, a little help needed please.
Been having some bad running problems recently. Car missing badly from all over the rev range, often the inability to rev, popping and banging etc...
Thought it could be the CPS so went to Ford and bought a new one. They said the original CPS for a FRST was replaced with the one they have given me...here's a picture.
To me the new one looks like it won't reach in as far as the old one, is this likely to cause problems?
The FINIS code for the new one I've got is 6859702.
Also...its like a bloody soap opera this car LOL.
I noticed this on the wiring.
Looks all melted. I suppose this could cause the above mentioned problems?
Any help appreciated as always
Old Sep 23, 2005 | 12:04 PM
Ginge !'s Avatar
Ginge !
just finding my feet
franky thats a cps for a 92 fiesta, the older ones are removed form service
there the same as the efi orion/escort/xr2i though but thats not the right one for the car, will work it but wont actually reach
also that melting does look like a very very possible reason
Old Sep 23, 2005 | 12:08 PM
EvilFranky's Avatar
EvilFranky
B19BAL - Cheers for the reply mate. So this new one will work but just isn't the right one for the car?
The old sensor may not be buggered if the wiring has been whats caused the problem, so i may beable to get away with using the old sensor.
Will try later and see...
Old Sep 23, 2005 | 01:16 PM
Ginge !'s Avatar
Ginge !
its the length as ya notice the sensor will work though , just not sure if it will be reliable enough for the ecu to read it
but on the other hand they are usefull when converting a mfi engine to efi as the frst cps sticks through too far
Old Sep 23, 2005 | 02:25 PM
EvilFranky's Avatar
EvilFranky
OK cool.
I've cut the plug off now
Can I buy a new one from Ford? Are they easy to fit?
Old Sep 23, 2005 | 02:52 PM
Ginge !'s Avatar
Ginge !
nope BUT pm ryan as he whould have em from farnell im sure and saves making a min 20quid order
Old Sep 23, 2005 | 06:55 PM
Ryan's Avatar
Ryan
cant buy them from fords im affriad.
but you can buy them from Farnell, VWP or me.
including terminals and a rubber boot.
PM me if you need anything.
Old Sep 24, 2005 | 01:00 PM
EvilFranky's Avatar
EvilFranky
Cheers anyways lads, I managed to get one with a few inches of wire from a local scrappy and seems to work fine...it hasn't fixed the problem though
And that XR2i CPS dosn't work i'm afraid, I presume its because it dosn't reach in far enough like I said above.
So what CPS to use then? Just for future reference more than anything, as I don't think this is what is causing my bad running now.
Old Sep 24, 2005 | 01:08 PM
Ginge !'s Avatar
Ginge !
franky ive got the cps ya need in me garage if ya om me the address ill send ya it out when i get time if ya not ina rush
the xr2i one will work though just not the one you was sold new
Old Sep 24, 2005 | 02:39 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
you will have to change the mounting bracket this unfortunately bolts on behind the flwheel so gearbox off etc.The new sensor will not work on the original cps bracket
Old Sep 24, 2005 | 03:16 PM
EvilFranky's Avatar
EvilFranky
Ahh, thats explains it then
B19BAL - You have PM mate
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
marky_g
Aug 17, 2015 12:21 PM
col93saphcos
Aug 7, 2015 03:21 PM
lockie
Jul 31, 2015 10:03 PM
