How Hard to put Cossie engine in Mk2???????
pretty easy as its a well walked path
WCXM
engine mounts modded unless the mk2 is an RS200 or already has a pinto.
Gearbox tunel need works.
back back needs minor triming.
few more things but theres a few.
WCXM
see this months classic ford for an awesome black mk2 rs2000 nosecone model
it's not at all difficult, but the quality of how you do it will vary depending on how much you want to spend on special parts like hydraulic clutch conversion, axle, brakes, radiator, intercooler etc.
I would love a cossie Mk2...
Some kind of relevant stuff...
Originally Posted by fatboyz
hi mate im st3v3 c s little bro i actually put that 188 bhp pinto in to the escort i can give you the complete spec of the engine later if you want but the bloke we bought it off paid Ł800 for the head alone . depending on what exhaust brakes etc you want a pinto wont just drop in as we were also told we put a rs servo on which fouled the exhaust cause the exhaust was 2 1/2 inch and the exhaust hit the engine mount so we had to fit a world cup cross member which then ment we needed a different steering colum joint then it didnt match the end of the colum bla bla bla and on and on it all went but i know a fair bit about the mk2s now so if i can help pm me mate do you have the escort already if so what spec is it ? have you looked at running gear etc we havw a capri 2.8i special back axle ( lsd will take 350 bhp) modded spring mounts anti tramp bars prop built by chards ( good for 400 bhp single piece) type 9 gearbox and a rs2000 alloy bell housing and clutch fork ( a pain to find in good nick as is the alloy sump and pick up all good fun hope some of this may help you will put spec on board later
i am buying a mint rs2000 for 3k already done ne ne ne ne ne just bought a stage 3 kit for the black beast last night to get it really moving anyone know where i can get a custom big front mounted intercooler for it or if a 500 1 will fit it cheers
just out of interest i've thought about this conversion before and which would be better
keepig the old leaf spring and axle ( if this is kept what diff do you use ?? ) or
fitting a saff subframe and diff ?? ( which i know is not simple )
thanks
thanks
kosienutter
31
22-08-2015 10:55 AM
JoeyBoyden
14
15-08-2015 10:51 PM
CabrioTurbo
01-08-2015 12:04 PM
