understeery lil so and so
1 Post
what can i do to make my escos turn in sharper without liftoff oversteer into fasy tight corners, forgot how "safe" the std suspension is, its running 18's with the right offset and fully poly bushed throughout, would fitting a set of ajsutable front TCA's be able to dial in a bit more turn in bite, if so , how many degrees camber should they be set to?
If you are really desperate you can set it toe-out 1-1,5 degrees. Might be a little bit tricky though... and will eat through tires quite quickly.
andre_k
23
04-05-2005 11:18 AM
rs_daz
14-11-2004 05:02 PM
