blue smoke... compression test result interpretation help!
hey i have lil puffs of blue smoke out of my s2, get a big 1 at startup (even if cars only been off for half hour), and throughout (esp when givin the loud pedal a lil kick up tp 2000rpm or so) loads of lil 1s come floatin by the passenger window
did a comp test, got 145ish psi all 4 cylinders when dry, wet test bought em up by about 10 psi, but my collage tutor ses dats ok...
hopin it aint me turbo, done nearly 90k on orig turbo, hasnt been chipped tho, was thinking about changin me valve stem seals but surely it wud only smoke on startup?
any help guys
dre
any help guys
dre
i have exactly the same prob even after i changed the valve stem seals
everyone has told me its the turbo im just lucky ive got another one thats being rebuilt at the mo
i still wanna do a compression test tho to rule that out
x x x
x x x
Originally Posted by J871yhk
valve guids and/or valve seals
dead common on cvhs!
Alex
Alex
My guess is the turbo or a blocked breather?
surely you meant shrek
Have you ever known Alan to be Enviromentally Friendly Hes a great entertainer as well! Can you remember when he first brought his Cossy down? We were playing joining the dot-to-dot for weeks with the oil leaks
PassionFord's crazy fool!
Mate, you're gonna find that most posts here drift in and out of the topic, it's just the way PF works, but you usually get your answers int he end so chill out lol
sorry guys, a bit stressed at the moment thats better lol
ive read about cvhs goin for 130k+ miles if looked after, got loads of docs for oil changes etc
CANT AFFORD A REBUILD!!!!!!!!!!!
stressed out again!!!
its pot luck with ebay really
but as uve said uve done a compression test so why dont u do the valve stem seals aswell as thats doesnt cost alot then if still smoking pm Danny@RADesigns off here and he shud be able to sort you out a price for the turbo
x x x
x x x
It Wasnt Me!
Have you tried cleaning out the breather? or even fit a new one, there like £7 from ford, also check and clean all the hoses for the breather (left hand side of rocker cover roundish black thing conects to rocker cover/inlet manifold at the top and metering unit) a turbo would smoke when u nail it in 5th from low revs and lift off on overrun, wld be more than just one or 2 puffs aswell
Originally Posted by andrek12345
sorry but ya dont know his username do ya?
cheeRS
dre
cheeRS
dre
here is his link so just post on that
https://passionford.com/forum/viewtopic.php?t=73616
x x x
but there is also a small pool of oil inside the inlet hoses...
dre
