secret cams
i found that too, when researching cams for my car!
basically no one wants anyone copying there cam choice.
thats why my final choice is secret too!
got them from Mountune tho!
DEYTUKURJERBS
Secret just makes you look special, like youve done some real research into your cams, when in reality you dont really understand the effect of different lift and duration on turbo engines and just used some off the shelf ones that seem to work well
"Secret" Zetec turbo cams usually means standard 130PS ones
some ppl will blatently rip you off aswell
sellin you somthing that isnt what they say it is
like difent inlet cam and standard exhaust cam and charging for a pair of hi lift cams
1st to 200 without NOS
[quote="Itsmeagain"]Secret just makes you look special, like youve done some real research into your cams, when in reality you dont really understand the effect of different lift and duration on turbo engines and just used some off the shelf ones that seem to work well
quote]
not true
quote]
not true
Fucking superstar........
I put a new cam in mine yesterday.
My secret spec. Is................................................ ..................................
Totally bog standard...................
Norris Motorsport
I always chuckle to myself when I read posts like this.
The honest truth amongst all tuners is you will find that for most "normal conversions" i.e. conventional 400bhp conversions etc you will find there are plenty of off the shelf cams that are adequate.........e.g. K2's, BD15's,16's etc. For these applications where hydraulic followers are adequate then it is the combination of these cams and the timing that is kept secret so that Joe BLogs on the street can't benefit with the knowledge for free!
However on all engines that I build that are 450bhp+ it is rare that I use off the shelf cams. Many of my engines run solid lifters and for these there are no "off the shelf profiles". In addition there are no suitable "off the shelf cams for engines with std pistons i.e. no valve cut outs, and for these engines I again developed my own hydraulic profile to improve on the std BD8 but prevent valve/piston contact.
Thus for people to think that tuners really don't have their own profiles is rediculous!!!
I for one always chat with Martin about cam profiles when we meet up, and can assure you that we both run can profiles in our engines that are vastly different from what you can buy over the counter and we certainly are'nt going to give that info away at any cost as it's taken time and money to evolve these profiles!
Hope that helps break the myths!!
Originally Posted by Glass Eye
Originally Posted by Alg1k
Unless your tuner really knows what he,s on about and does have them ground especially for your engine
secret,my arse!
how much bhp can you make without changing your cams,on an esc cos? my brothers old car made about 415bhp,with standard head too. is that the limit?
Originally Posted by yrkesman
How much are these "secret" cams? Any rough price for them?
Someone like newman will grind you cams to whatever spec you want for a couple of hundred quid a stick but its the knowledge as to what to ask to have grind thats kept quiet.
Mc5506
05-10-2015 09:57 PM
