View Poll Results: What one failed on your cosworth block
Voters: 12. You may not vote on this poll
Cosworth BLOCK No 4
Cosworth BLOCK No 4
why does this one 99% always be the one that melt's or knackers ?
just i had three dif rebuilds (on dif blocks) and all been problems making this fail
Caraholic
It's normally No. 2 or 3 (particularly No.3), as these get fed the most air out of all four cylinders due to the design of the plenum. So for you to have problems with No.4 on all occasions, suggests to me you have a fuel supply problem and that you should be checking No.4 injector out in particular.
Normally the middle ones that fail, they work harder and get less cooling.
What failed specifically though when it went?
If its bearings, it could be an oil supply problem as often that will manifest itself first furthest from the pump
Caraholic
Paul,
It doesn't matter WHO builds an engine, if it has a fuelling problem or is mapped incorrectly, God could have built the engine and that wouldn't save it .
It just seems really bizzare that you have had the problem on No.4 on all your engines, when in my experience (and most other's), it is the middle two ?
Originally Posted by RS500/104
All were built by dif pepole
Harvey Gibbs x2 wont be there again
in two dif cars less then 3k out of both
OMG!!!!! My engine pics: SCS build..........5 k miles and then this, on number 4 pot:
Doug, that is NOT a build issue.
Absolutely categorically definately not.
So please dont try and implicate harvey for that one!
Looks more like an injector clip came off on an 8 injector setup or something along those lines?
(or some other reason for it going lean on that cylinder only)
But never live mapped once in the car . Some people .
Caraholic
just not going to spend Ł3k on a enigne when i can get it mapped forŁ1k and be running safer
Paul,
James Porter
28-10-2015 12:17 PM
Jack and the Beanstalk
09-08-2015 07:03 PM
