bedding in procedure
Old Jul 14, 2005 | 06:23 PM
craig todd's Avatar
craig todd
Default bedding in procedure
just fitted new front brakes, nothing special just standard mintex.
just wondering if theres any bedding in procedures on them, what do you guys do?
the ones that i took off were warped and i dont want these ones to.
any advice much apreciated
Old Jul 14, 2005 | 06:39 PM
plynchy's Avatar
plynchy
Take it easy(if possible) for first 200 miles or so and try and avoid any hard braking.
Old Jul 14, 2005 | 06:47 PM
Billabong's Avatar
Billabong
Have you just changed the disks, or disks and pads?
Old Jul 14, 2005 | 07:10 PM
craig todd's Avatar
craig todd
changed both m8
cheers plynchy
Old Jul 14, 2005 | 07:14 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Opinions vary on this one, iirc ferrodo recommend braking hard (can't remember how hard) several times, that's what's written on the paper that comes with their 2500 pads.
Old Jul 14, 2005 | 07:43 PM
craig todd's Avatar
craig todd
cheers frog
but i'm stuck now with what to do, hard braking or take it easy
Old Jul 14, 2005 | 07:47 PM
GARETH T's Avatar
GARETH T
you really should bed new disks in with old pads for a few miles! then change the pads
Old Jul 14, 2005 | 07:51 PM
craig todd's Avatar
craig todd
will put the old ones back in then as they're still good.
cheers m8
Old Jul 14, 2005 | 08:15 PM
Billabong's Avatar
Billabong
Craig, the reason I ask was partly to do with what Gareth said. Taking it too easy can glaze the pads up and screw them, the way mine are usually bedded in is to get some heat into them and allow sufficient cooling time between applications.
Remember also, to try not to keep your foot on the brake as you come to a complete stop from high speeds, as this can cause thermal problems with the disks.
Old Jul 14, 2005 | 08:19 PM
craig todd's Avatar
craig todd
cheers m8
dirty-diesel
12
Dec 23, 2018 08:29 AM
slammedorion
15
Nov 1, 2015 07:17 PM
23
Sep 12, 2015 12:56 PM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
