heater matrix
Also, if you dont do something with the pipe work you will get wet feet
does the car have a cooling problem at the moment? if so you should fix it rather than try n cover up the problem like yu're doing...
unless you men you wanna remove the matrix to save weight for a track car or summink? or you have a fettish about being cold in the winter?
i havnt tryed everything i asked for help but noone had any ideas theres nothing left to change.
but yes it is a track car and yes i do want to save as much weight as possible.
Originally Posted by Jim Galbally
bypass it then
but if that isn't your problem, then you're just covering up other issues that still need looking at
lol wat r u on about im doing ti to try it as there is nothing left to try its got anew rad new pipes new water pump new header tank new thermostat housing new thermostat. new gaskets new coolent been flushed thro 3 times.if u can think of anything else i can try please let me know as im stumped.
and the head gasket seems fine the car drives spot on just gets very hot.
are you 100% confident that the system is properly bled?
also have you checked to see if your h.matrix is blocked?
oh, and have you tried a new header tank cap
do you have a big intercooler blocking the rad or anything?
also what are you using to check the temp, just the standard gauge? or an aftermarket gauge?
i have checked the gauge and its working fine but have put an after market one on to and changed the sender.
the header tank cap is new
think ive bleed the system properly
i do have a big intercooler bu thats not the problem as its not blocking the rad really.
im taking thte matrix out to try it as it was coming out anyway.
thanks
thanks
how did you go about bleeding the system mate... as ive seen SO many people do it wrong n then wonder why the car gets hot it's unreal!
are your temps normal when cruising on motorway n stuff?
no even on the motorway witht the fan on its still gets very very hot.
i bleed it by leaving the cap off and letting it run up hope thats rite??
My matrix split about a month ago
So just joined the 2 hoses together in the engine bay
Does get a little hotter in warm weather, but drops like the titanic when its cool
Oh and I no longer have any heaters
youll have to pump the hoses a lot with your hands (prefably wrapped ina towel or summink coz they get VERY hot) also youre suposed to let her run up to the point when its just about to boil out of the header tank, then quickly put the cap on n kill the engine, then let it all buble about etc for a sec... whe the level starts to drop again slowly open the cap a bit to let the air out, dont let the (VERY VERY HOT) water escape tho if you can help it...
keep repeating this till no more air comes out then just make sure the water level is always kept topped up (as the water cools the level will get lower)
you may have to repeat this process LOTS of times
i spent most of the morning saturday bleeding mine as its a pain in the arse to do sometimes, and i kept making mistakes n letting all the fookin water boil out
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
