fuel pumps which one?
Old 05-07-2005, 07:29 PM
leecavturbo
leecavturbo's Avatar
Default fuel pumps which one?
any gen stu@msd?
i would of searched if it was working so, where from and which one walbro or bosch ?
Old 05-07-2005, 07:34 PM
Billabong
Billabong's Avatar
Personally, I'd go for the Bosch.
Old 05-07-2005, 07:35 PM
ImaRacing 700
ImaRacing 700's Avatar
Strangely...so would i
Old 05-07-2005, 07:50 PM
leecavturbo
044 ? what filter ? how much ?
Old 05-07-2005, 07:53 PM
ImaRacing 700
See Stu @MSD mate
Old 06-07-2005, 06:57 AM
Ian Godney
Ian Godney's Avatar
Lee , Have sent you an PM for the ECU , can you let me know when I can have it , getting desparate now
Cheers Ian
Old 06-07-2005, 07:14 AM
Stu @ M Developments
PassionFords Creator
PassionFord Gold Member (Male)
Official PassionFord Trader
Administrator
Stu @ M Developments's Avatar
In tank or external?
What horsepower estimated? (Or fuel flow required ideally) and importantly, at what fuel pressure will she make peak horsepower.
Old 06-07-2005, 09:18 AM
leecavturbo
realistic 360 but wanted 400 and the spec should give it but i usually don't get what i want 3.5bar running 525cc inj
any tips on fuel line setup swirl tanks pre pumps and all that pro's and con's
thx
p.s will be trackdaying it most weekends O and my pump,filter,damper is all external mounted on a plate by the fuel tank.
Old 08-07-2005, 02:27 PM
leecavturbo
any tips stu ? thx
Old 12-07-2005, 06:08 AM
Administrator
3.5 bar is line pressure i expect?
What boost do you plan to run and is the rail rising at 1:1 or greater?
Old 14-07-2005, 12:14 AM
leecavturbo
my theory was approx 20psi but can raise it to make the figures and deal with detonation if it arrives etc ? 3.5bar yes on 525cc injectors,dta p8pro,gt2540r turbo(not the hks one)supposed to be ideal at 440bhp? 7.9:1 C/r,some head work, the rail ! i have no idea what that means, but at a guess the rail pressure rises 1 bar for every 1 bar of map? then yes
Novice alert
JK12
33
26-04-2021 12:09 PM
155lee
27-10-2015 04:55 AM
155lee
24-10-2015 11:11 AM
wheelwizardrefurbs
23-09-2015 09:21 PM
tib2220
14-09-2015 12:33 PM
Quick Reply: fuel pumps which one?
