S2 help needed
Old Jun 21, 2004 | 08:00 PM
Krazy Kim's Avatar
Krazy Kim
Default S2 help needed
Got the gearbox fitted last weekend and need to get the cooling fan sorted as it's....er....not cooling, and the engine is overheating but when i took it for a spin it keeps stalling at every junction.
I have to use the handbrake and keep the revs up so it doesn't stall.
Any ideas as to what it could be?
Old Jun 21, 2004 | 09:40 PM
AndyRST's Avatar
AndyRST
check the dip stick is pushed in fully and the oil cap is on and tight.
I sounds like an air leak causing it to idle low and stall.
Old Jun 21, 2004 | 09:43 PM
L33 BYT's Avatar
L33 BYT
Mine used to pop the filler cap off all the time and stall.
Old Jun 22, 2004 | 05:32 PM
AndyRST's Avatar
AndyRST
what intercooler you got and what cooling fan you got Kim ?
Old Jun 22, 2004 | 05:47 PM
Andy_R's Avatar
Andy_R
Kim as per Andys reply the staling does sound like an air leak, a common cause of this is either a hole or split in 1 of your boost hoses. Or an Dumpvalve that aint working propperly. Do you have a dumpvalve fitted?
The problem with the fan could be down to a number of factors, shouldnt be a major problem to diagnose.
Andy
Old Jun 22, 2004 | 07:18 PM
Krazy Kim's Avatar
Krazy Kim
No, don't have a dump vaulve and the intercooler is from a 2wd cosworth.
I checked the hoses and there's a leak coming from one going into the petrol tank????? The oil cap is on properly and the dip stick is in tight.
Old Jun 22, 2004 | 07:32 PM
AndyRST's Avatar
AndyRST
are you saying you got a petrol leak? If so dont drive it or even start it without getting it fixed PROPERLY 1st!
The hoses that can cause stalling are the main boost hoses (there big hose) that might cause an air leak.
What fan have you got? Is it the standard RST fan?
Old Jun 22, 2004 | 08:08 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
Could be a headgasket if it overheating and cutting out.
Old Jun 22, 2004 | 08:11 PM
EIL132's Avatar
EIL132
As Tony, they don't like over heating.
Old Jun 22, 2004 | 08:33 PM
Krazy Kim's Avatar
Krazy Kim
Tony: It cuts out immediately from cold
AndyRST: Got a new fuel hose on order!!!!!!! I'm pretty sure it's a standard S2 fan.
Old Jun 22, 2004 | 08:48 PM
Mungus's Avatar
Mungus
Hi Kim... Andy Grangers old one?!!
Dont suppose you have had the rocker cover off have you? The slightest kink in the gasket on refitting with make the car run like a dog! Also, check the breather pipe going from the right hand side of the rocker, down to the block (crank case breather).
In fact, take it off and blow it through as these are common to block with ....crap basically!
As for the heating problem, I think Andy did a headgasket before on it? I think I got that from the RSBB. Anyway, obveously no sign of crud in the oil cap or on the header tank?
Huw
Old Jun 22, 2004 | 10:45 PM
Krazy Kim's Avatar
Krazy Kim
No crap at all. The car runs fine on boost and stuff it's just this annoying problem with the stalling!
It is Andy's old one. Just itching to take it for a bloody good blast!!!!!!!!
Got some smoked rears for it too
Keeping the originals before anyone asks.
Mint motor, it's just that all the lads have got great cars and take them to shows and up the pod and i get bored after a while but now i can join in and it's my first tubo'd car so i don't know much about them and really appreciate the help you guys have been. Really proud of getting this motor and wanna do right by it. Know what i mean?
Old Jun 22, 2004 | 11:23 PM
EIL132's Avatar
EIL132
Before my head went, exact same problems. MK5 radiator which ran hot, idled worth a fuck, but ran well = resulted in £600 head in the bin
Old Jun 23, 2004 | 08:02 AM
Rolls's Avatar
Rolls
hope you get it sorted kim!!!!
Old Jun 23, 2004 | 10:10 AM
Cawood's Avatar
Cawood
could it be the airflow meter?????? i'm having similar probs wi mine stallin and been told its the airflow meter
Old Jun 23, 2004 | 06:13 PM
Mungus's Avatar
Mungus
Know what you mean Kim.
Have you got a compression tester?
If so, do one (pref with the engine warm). Naturally do one at a time and the readings should be between 130 -140 psi on each cylinder. If there is a significant drop on one or more cylinders, there is a problem.
If they are below 120, its not lookin that good!
Get back to me if you need a hand.... where are you btw?
Old Jun 23, 2004 | 06:20 PM
Mungus's Avatar
Mungus
Old Jun 23, 2004 | 07:11 PM
alan rainbow's Avatar
alan rainbow
there is a over ride switch for the fan in that car when you say the fan is not cooling do you meen the fan is not comeing on or fan running and over heating
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
