any bike mechanics / know it alls out there? gsxr600
gsxr600 99 v reg needs new clutch as slipping, also the exhast manifold gaskets are leaking i believe there ceramic?
how hard to do a clutch how much i looking at to have one fitted?
seen this place that sells a clutch for 37 quid but think its just the plate??
http://www.gear4bikes.com/acatalog/S...tch_Kits1.html
im fine with cars but bikes im in the dark
If your a competent mechanic mate the clutch should be a doddle,all you have to change usually is the fibre plates,only change the steels if they are blued to fook....
I`ll pm you my number mate .........give me a bell and ill talk you through it ....
oh so there not that bad then? spose a manual would be a good idea
nightdavva havent got the clutch yet havent even stripped the bike but suszuki quoted me 400+ to suplpy fit clutch and man gaskets lol
Originally Posted by apples24
so wots the process for clutch change?
Fairing off, clutch cover off, undo the 6 or so bolts in the middle of the clutch basket.
Remove the cover, pull out the alternate fibre and metal plates.
As said, only replace the metal plates if they are badly scorched.
Reverse to put back together.
Really easy job
Clutch change proper:
remove lower fairing
drop oil
remove r/h side engine casing
remove the 6 bolts from clutch cover and take off to expose plates
carefully remove plates one at a time noting sequence they come out
check steel plates for blueing and high spots
soak new fibre clutch plates in oil for half hour
rebuild clutch as it came apart with new fibre plates and replace cover
Carefully tighten/torque cover bolts(9-11lb ft)
replace engine casing
refill with oil,run up and check for leaks and correct clutch operation
replace lower fairing....
Easy huh.....
Replace clutch..Endurance method:
Drag rider off bike and chuck him in corner of pit garage
rip lowers off and dump bike on its side
buzz engine case of with airgun as quick as poss
while keeping now snarling rider at bay,tear clutch out and replace
throw thing back together and unleash psycho on to track again
Seek treatment for 3rd degree burns to fingers.......
drop oil
Easy huh.....
hmmn according to the manual thers a friction plate with a larger internal diameter that gos in first etc then a plate then another friction plate etc etc but for the 600x model (mine) it says theres a friction plate that gos last that on original clutches has a green dot but i have a ebc aftermarket clutch, how will i know which is the one?
james kiely
28-08-2015 08:58 PM
