while to start?
Old Jun 20, 2004 | 01:45 PM
kris's Avatar
kris
Default while to start?
i have to hold the throttle fully open and turn my s1 over for 20+seconds before it'll even fire then it will tick over and cut out it needs re starting about 3 times before it'll idle.once its warm its ok unless you turn it off for more than 5 mins then it wont tick over until its been thrashed down the road.peed off with it now as my s2 always started first time in the morning and never had any problems can anyone help?
cheers kris
Old Jun 20, 2004 | 02:16 PM
escort1989uk's Avatar
escort1989uk
cold start valve or some thing i belive common problem ask for a list of thing to check from one of the members of here they will all try to help
Old Jun 20, 2004 | 02:28 PM
kris's Avatar
kris
any ideas will be good i'll start checking tomorrow
Old Jun 20, 2004 | 02:32 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
maybe idle mixture is a bit lean? errr, what does it idle at when its cold and what does it idle at when hot? maybe turn the idle up slightly if its about 800 (where most shuld idle) but helps it stay runnin when cold if its 900-1K unplug cold start valve (blue plug underneath inlet manifold at the back with a red fuel hose going to it)
Old Jun 20, 2004 | 06:32 PM
kris's Avatar
kris
my s2 didnt have the cold start inj connected but my s1 wont start without it?
Old Jun 20, 2004 | 06:36 PM
L33 BYT's Avatar
L33 BYT
Yeah disconnect your cold start first. Then try your thermo switch and temp sensor on and around your inlet manifold. If unsure of location the haynes does show ya.
Old Jun 20, 2004 | 06:41 PM
kris's Avatar
kris
does anyone know what readings i should get from these sensors so i can test them to find the wanked one instead of replacing them all?
Old Jun 20, 2004 | 06:42 PM
vroooom ptssssh
It Wasnt Me!
mine started with a fooked temp sensor (was a bit of a pain to get it started tho when it was broke) but starts first tiem everytime now i fixed it!? lol
Old Jun 20, 2004 | 06:49 PM
kris's Avatar
kris
are they expensive?i think i only got two on my s1in the inlet manifold if they aint too bad i'll just buy both
Old Jun 20, 2004 | 07:00 PM
vroooom ptssssh
It Wasnt Me!
temp sensor is cheep as chips and easy to fit, time switch shuld be cheep too i'd immagine and prob easy to fit too !
Old Jun 20, 2004 | 07:02 PM
L33 BYT's Avatar
L33 BYT
Got mine from Halfords at one hell of a price.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
TPM961
Jan 15, 2018 10:50 AM
xrmalin
Sep 13, 2015 06:52 PM
stevierob
Sep 7, 2015 07:09 PM
