Punto GT Problem
Hi ppl,
I have a Sick Punto GT,I was chasing a Honda Integra a while ago,while it was on full boost it started missing badly as in the plugs had fouled and the temp gauge went through the roof!
it also now bellows white smoke while on tickover (Turbo buggered) regards to the temp etc and the plugs would the turbo have taken the headgasket with it as well or has it holed a piston?
Thanks
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Thanks
Oops sorry, I mean't does Jano supply Actual Turbo units for Fiats?
I took all the plugs out form right to left the furthest right one was oilled up the rest are fine ..all tips in place
It Wasnt Me!
check the cylinder with a long screwdriver for a hole on the piston which the oily plug came out of, or if you can do a compression test easily do that!
does it still tick over perfect or a bit lumpy like it's still missing?
well if it were oil it would be burning blue smoke as its white it means water so my guess is head gasket or turbo check your water level in ya expansion tank
(This is for my mate I used his login before at his house)It did run low on water so I'm guessing the headgasket popped,but what about the oilled plug? it was only the one plug that was oilled up
Any chance both i.e Headgasket and Turbo could have been taken out at the same time? it bellow's white smoke on tickover and I can't see it boosting on the Boost Gauge? I know it did lose water so I presume the headgasket is deffo gone
Originally Posted by Graceland
one oiled plug = one melted piston ![Wall](https://passionford.com/forum/images/smilies/wall.gif)
What would make it bellow smoke? knackered piston?
"look i can fill my oil up in four holes"
Team HOTHOT!
my drink jsut come down my nose from that comment
Ok so the piston is Fucked lol
Sounds like the turbo died as well? or maybe the headgasket instead? when a headgasket goes does it smoke like a knackered turbo?
If your turbo's not fooked I'll buy the fucker
just scrap the car there shite trust me, I've got one in a thousand bits outside
Does anyone do turbo's on here? I'm on my third from turbo technics, fookin waste of life.
Might just be the turbo. I did this on my S1. Ran like a sack of shat and kept oiling plugs up and it white smoked like a bitch as the oil was pouring into the turbine housing and not being burnt by the engine. I take it the turbo is water cooled?
I would remove it and have it stripped and inspected first.
i work on punto gts for a living and can say its ither head gasket or cracked piston and they normaly brake around the piston ring grove best bet take head off coz you already now youve blown head gasket and just take a lok from ther
Ask me a question!
I can be contacted via email jano@oddkiddcreations.co.uk
Regards
Jano
Ask me a question!
IHI Turbo........Hmmmmmmm
Well you see the problem is they are not the greatest Turbo's to start with, the Thrust plate is not a great design. If i were to build a Hybrid i wouldnt be able to offer a warrenty as the shit themselves way toooo often.
Hybird is an option but not an option i would consider as the Turbos are not the best to modd.
Regards
Jano
I hope you understand.
The cost of a Std Turbo exchange is around Ł350-400 contact me via phone if you like or email.
07050 133596
Email is above
Regards
Jano
07050 133596
Email is above
Regards
Jano
07050 133596
Email is above![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Regards
Jano
07050 133596
Email is above
Ask me a question!
Dude your problem is that this Turbo has only one type of thrust that can be used.
The best option for you is the T25 with larger comp wheel and housing, 360 bearing, adjusting shaft seal, new gaskets bolts seals etc...
The Turbo unit will be Garret and is by far a better choice. The only part you will need to change is the downpipe on your exhaust system.....
The price is around Ł500
Regards
Regards
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
