Oil pump gasket on 4x4 ?
Just putting my cossie 4x4 block back together.
Went to refit the oil pump and the gasket kit I have has a gasket for pump to pick up, however there is no gasket for pump to block.
Now I'm not sure if there def is one but to me it would seem that there should be one between the punp and block, can someone inform me if I'm correct or not ?
No gasket between pump and block, make sure there is no gap between oil pump face and block when oil pump has been bolted on (use some feeler gauges to see if there is a gap or not). Also, make sure gasket between pickup pipe and oil pump is fitted the correct way round, one way is fine , the other blocks half of the tube.
JK12
33
26-04-2021 12:09 PM
