Cossie crossmember
Old 28-05-2005, 05:30 PM
david
david's Avatar
Default Cossie crossmember
Is a 2wd saff cossie front crossmember just the same as fitted on a normal 1.6/1.8 saff ??
Old 28-05-2005, 06:09 PM
DOO
DOO's Avatar
same as normal saff
Old 28-05-2005, 06:39 PM
david
david's Avatar
Cheers Doo
1 less part to swap over
Old 28-05-2005, 06:46 PM
Moose 130
Moose 130's Avatar
doesn't the inner arm bush run a 10mm bolt on std ones and a 12mm on a cosworth?
if so, get the drill out!
gcfcos
59
06-10-2015 05:04 PM
XR4
Ford XR Range
01-10-2015 12:46 PM
A.t.p
29-09-2015 05:04 PM
cossie330
27-09-2015 04:13 PM
Russ Payne
25-09-2015 08:29 PM
Quick Reply: Cossie crossmember
