cvh engine rebuild
i am rebuild my cvh rst engine and my big ends bearings looked like this 5 upper and 5 lower bearings
![](https://img.photobucket.com/albums/0803/hansenturbo/IMG_1569.jpg)
i got some new bearings from Ford
10 bearings upper bearings i said to the guy at Ford how the old bearings was but he told the 10 big end bearings sould be like this one is he rigth
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
![](https://img.photobucket.com/albums/0803/hansenturbo/IMG_1570.jpg)
The bearings you have been supplied by ford are really for the good old xr3i engine, when ford upgrade the cvh for turbo use the replace the bottom shell bearings with the plain bearing " with out the grove in the centre"
But most ford agents no longer stock them and I have found them very had to get hold of in the past.......
I have run both types of bearings in past engines I have build and it does no seem to make any difference which bearings you end up using..... ? But if you can get hold of the original plain ones that would be my recommendation.
ps make sure you use a Ford oil pump.
Steve
Steve
So the Ford dealer was right you can only get this type of bearings for the big ends now as they don`t have the plain sheels anymore
Depends what engine you have age wise the ones you have been supplied are right for the mota sport s1 blocks the others 86 on have offset tabs.So you are right in both cases.
lol Hope that helps lol my s1 block has 10 of the grooved shells and that is right cos the solid shell has the tab in wrong position.
This has it benifits as the big ends see oil pressure all the time unlike the 86 on shells.
but ill use 10 grooved bearings then thanks guys
track.focus'd
12-08-2015 05:53 PM
Zoggon
10-08-2015 10:39 AM
