EGT Gauge
Ive just fitted a new mongoose exhaust which has a fitting welded in on the downpipe for a lambda sensor so though it would be rood not to have one!!
Whats needed to get me an EGT gauge fitted to my car??
Any ideas appritiated people
AFR being air/fuel ratio, id like an EGT gauge aswell thow.
Wasnt sure on what was needed or where its mounted,just assumed with having the fitting on the exhaust it would be ok?
Originally Posted by ballin
whats a lambda sensor got to do with an EGT guage?
dunno which boss you have, but a guage + wiring is generally what you will need![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
yeah air/fuel ratio uses lambda, which is what is on your exhaust by sounds of it.
will need either a wide or narrow band gauge + the sensor. narrowband = £100ish and is for looks only, wide costs i believe £300++ and is good for tuning!!!
egt will need a new sensor welded + guage!
oh okay sorry posting at same times!!!!
if you dont want the afr gauge then im sure you can get an adapter you use an EGT probe instead
Where can these bits be brought from, dya know?
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
