Just got back from Interpro Rolling Road........
Old May 12, 2005 | 04:10 PM
Disabled Account's Avatar
Disabled Account
Default Just got back from Interpro Rolling Road........
Just got back from Interpro Rolling Road with Phil 2400.
Phil's just rebuilt/run-in his engine (his 200 block had cracked within one of the cylinders).....So he's done a rebuild using his old 205 block
Nice Stage 3 spec RWD Cossie - goes very well
SCS Chip
Greens
T34
Pace 500 intercooler
Plenty of bling........
341.5 BHP on 22 PSI boost........fueling spot on
Old May 12, 2005 | 04:14 PM
GARETH T's Avatar
GARETH T
i bet thats goes really welll
Old May 12, 2005 | 04:15 PM
TIFF's Avatar
TIFF
Chasing Radders
What color is that Sapphire??????????????
Old May 12, 2005 | 04:18 PM
Disabled Account
It does go well Gareth - could not get a torque reading today.....but it made
356 LBS/FT on Harvey's rollers when first set up just over a year ago
Old May 12, 2005 | 04:22 PM
Disabled Account
Rover Tahiti Blue.
Previous owner had a bad accident - creased up the shell/floorpan.....so car was rebuilt using a brand new 4WD shell and painted by Yeovil Ford (main dealer).
Old May 12, 2005 | 04:23 PM
Disabled Account
Old May 12, 2005 | 04:24 PM
Andreas's Avatar
Andreas
Blue
Old May 12, 2005 | 04:27 PM
TIFF's Avatar
TIFF
Chasing Radders
Very Nice Doug
Andreas
Did you get a printout of BHP figures at various points Doug?
If so i can tell you the peak torque mate
Old May 12, 2005 | 04:31 PM
Disabled Account
Yes, the lines are a bit feint - will post up in a few mins
Old May 12, 2005 | 04:47 PM
Doug, best thing you can do is write the figures down every 250rpm, if thats possible?
Then ill quote the torque back to you, or a clever bloke like yourself can work it out easily using the following formula:
Torque = (BHP / RPM) * 5252
Then you can draw the torque curve
Excel is your friend here of course, put rpm in one column, then BHP and that formula for the third column
Old May 12, 2005 | 04:48 PM
Disabled Account
Old May 12, 2005 | 04:51 PM
Rhys's Avatar
Rhys
Doug was there a Blue Rover over there with a big cut out in the front for Intercooler etc by any chance?
Old May 12, 2005 | 04:54 PM
Doug how many rpm is it doing in whatever gear that was at 90mph mate?
Cause thats the point he hits peak torque.
Old May 12, 2005 | 05:10 PM
Disabled Account
We saw the Rover outside - same colour as Phil's Cossie
Photoshop enhancement:
Old May 12, 2005 | 05:12 PM
Disabled Account
Dont know what gear it was in.........run was to 120 MPH so...4th gear??????
Dont know what RPM either
Old May 12, 2005 | 05:29 PM
Lol, cant really work it out without knowing that.
I guess they would have taken it to about 7k?
Assuming 120 was 7K then 90 would be 5250 or so, at which point torque and bhp are the same anyway so about 310lbft or so.
But obviously if 120 isnt 7K then thats totally wrong!
Old May 12, 2005 | 05:34 PM
Disabled Account
It deffo produced more torque than BHP on SCS (Harvey Gibb) rollers when that chip was installed - IIRC it was 356 LB/ft.........
Shall I draw a torque curve in - then you can tell me if it's right or wrong???
Old May 12, 2005 | 05:45 PM
ImaRacing 700's Avatar
ImaRacing 700
...lost alot of BHP for a 2wd tranny...i suggest it was on "bullshit flywheel mode" as 341 @ 22psi is a tad optimistic imo.
I will say it again a Rolling Road is a diagnostic tool only.
Old May 12, 2005 | 06:00 PM
Rhys's Avatar
Rhys
Cool, typical they wasnt working on it agian though
Cool that the saff is back on the road
Old May 12, 2005 | 06:11 PM
All4it's Avatar
All4it
looks blue on my pc screen Tiff
Old May 12, 2005 | 06:14 PM
Disabled Account
I know the S*IT that this could cause...but my (estimated) torque curve added.....359 LB/ft @ 3,800 RPM
Old May 12, 2005 | 06:48 PM
Sketch's Avatar
Sketch
Chip / Doug....
Assuming it was run in 4th gear (1:1) with a rear diff ratio of 3.62 (got that figure in my head as RWD diff ratio) on 215 40 17 tyres (which i think is what Phil is running.....
90mph is approx 4600rpm.
Looking at the graph, its somewhere around 310bhp at 90mph / 4600rpm, therefore
Torque = (310 / 4600) * 5252 = 354 lb/ft
Obviously that figure could be toooo low or toooo high, dependant on the exact revs that peak torque was made / the guess work in the power at those revs / whether I've got Phil's tyre size right and whether i've got the diff ratio right?
Old May 12, 2005 | 06:53 PM
Disabled Account
Originally Posted by Sketch
Chip / Doug....Assuming it was run in 4th gear (1:1) with a rear diff ratio of 3.62 (got that figure in my head as RWD diff ratio) on 215 40 17 tyres (which i think is what Phil is running.....
Torque = (310 / 4600) * 5252 = 354 lb/ft Obviously that figure could be toooo low or toooo high, dependant on the exact revs that peak torque was made / the guess work in the power at those revs / whether I've got Phil's tyre size right and whether i've got the diff ratio right?
Thats close enough Sketch.......lets just say we've "allocated" him between 354 - 359 lb/ft ... I'm sure Phil will be happy with that
Old May 12, 2005 | 07:43 PM
ECU Monitor Enthusiast
Doug, NOT having a go but the above statment is very fishy !!!!
I know Phils car is quick but if interpro told him that torque could not be measured then that is a complete untruth !!!
Dynos/rolling roads do NOT and CANNOT measure BHP.
It is back calculated from TORQUE and RPM only.
With out either measured the BHP cannot be shown.
If a Dyno/rolling road could not measure torque then it CANNOT calculate BHP.
Sorry but something aint right there @ interpro
Old May 12, 2005 | 08:33 PM
phill2400's Avatar
phill2400
Its not that we couldent get a torque reading at the time it just wasnt on the graph and didnt think to ask why at the time??
Old May 12, 2005 | 08:47 PM
Ginge !'s Avatar
Ginge !
just finding my feet
thats such a cool colour
andy130
Oct 2, 2015 08:48 PM
3drRich
Sep 13, 2015 07:32 PM
1300gt
Sep 7, 2015 12:06 PM
turbotrev
14
Sep 6, 2015 10:27 AM
