XR4 ti engines - any good?
Testing the future
the 2.3. i have heard reports from the states that some people are getting massive power out of them. is that with a lot of internal mods?
what is a brand new one (complete with all manifolds, turbo, dizzy, flywheel, everything) worth? would you give 500 for one? would make a good project for an old skool cortina or granada or something i would've thought
K155MYRS
Re: XR4 ti engines - any good?
My tuner's XR with a standard block and his own custom head with other mods was producing 396hp at the wheels, Now he has 623@ the wheels. (with 2.5 stroked block, his custom head and other mods) everything minus his porting and custom intake and Ex manifold is basically off the shelf stuff.
so a standard 2.3 turbo engine from the above mentioned cars can produce the big power. Taryn's car is almost done and when broken in will get dynoed to see what it does.
K155MYRS
Here you go, I had to look for my old post...can't even copy and paste the topic.
Here you go dude,
87 Merkur XR4Ti Work done by Phil Marshall (PM Motorsports)
Engine Specs:
2.5 stroked block, Crower 5.5 rods, Wiesco Piston 8:1 .30 over,
Total seal rings.
PM stage 3 8V Head fully ported and polished, 527 lift cam, 1.9 Intake valve 1.60 exhaust valve, mechanical lifters,
triple valve springs, mouse traps for the vales spring. Race Engineering adj cam pulley
Custom PM intake with 80mm throttle body, 95lb injector,
Aeromotive fuel pressure Reg. K&N filter
Custom PM exhaust manifold, T-72 turbo
Tial BOV and 46mm External WG
3 1/2 inch downpipe to 4 inch dual exhaust
Haltec engine management
Mustang Intank fuel pump
Aeromotive external fuel pump
Standard T5 with race clutch
modified drive shaft
BMW rear with 4.10 gears
623.5 Wheel Horse power
425.7 ft lbs torque
11 sec 1/4 with slipping clutch @ 137mph.
Here you go dude,
Engine Specs:
Total seal rings.
425.7 ft lbs torque
I just love the way that the engine is so old it doesn't have mousetrap springs on the retainers as standard (pintos do!!!) and yet it can make stoooooopid amounts f power - properly built 8 valves rock
K155MYRS
Originally Posted by Moose 130
Acording to an old copy of Car Craft or Hot Rod a guy called Joe Morgan (sure that's his name) has achieved over 1000hp (US Hp ) from one.
Also heard they can be converted to 16v using a Volvo head.
Not sure if that's true or not!
And Taryn "testing" out the 16v XR. lol
how long is that going to hold eric? until she is ran in?
Testing the future
thanks for the replies so far guys.
it doesn't come with ecu, but could easily be converted to run cossie management i imagine by fitting cossie crank pulley and dizzy (or other phase sensor) and then my S8 ecu would run it no problems.
eric, but what about std pistons, rods and crank? and std valves? what are they made of? and what is the standard turbo?
how much boost/power do they make as standard in the SVO? i'd be looking for something like a reliable 300 bhp at the flywheel, but only on std parts. i wouldn't want to change anything on the bottom end.
would a 2wd cossie clutch fit, and the 2wd cossie t5 bolt straight up on the belhousing?
a lot of questions, i know - hope someone is interested enough to answer. still want to know if a new one is worth 500 quid? i would say that if all 2wd cossie clutch and gearbox fit, and 300 bhp can be had easily on std parts with a good intercooler and 4 x 803's i'd say that it's got to be?
Rene, hi mate the blue cossie we bought off dave still isn't finished. my mates are useless slackers, so it's down to me to babysit them through the rebuild. should be running by the end of tonight though. we then have to get tuv, and get it registered. hope to get that done before the weekend of 21st/22nd. will you be attending the 'ring that weekend?
Hope some of this helped. Erik can chime in with anything I may have left out. (hey, I can get ya parts if ya wanna trade for some cossie sturf )
K155MYRS
Joe or TurboXR LOL pretty much answered the questions.
300hp at the flywheels??my car was very close to that and I spent less than 2k US!! try 300hp AT Wheels..
standard block internals see's it's limit at about 400hp +/-(again at the wheels)
I don't know or think that the Cossie engine mgmnt would fit, or be worth doing. Also we don't use color injectors, but lbs per hour..
Here's your recipe for 300hp
fully ported and polished big valve head
RS500 type IC, custom log intake, T3/4 turbo
20psi boost, 3inch exhaust..little things here and there and yo have it.
All the power for these cars come from the head, that's where the magic is at lol.
Testing the future
thanks a lot for the information guys. unfortunately i'm going to have to pass on it. i've got too many things on the go already, and am moving back to england in september / october time, so it would just be a pain in the ass to have to bring an engine back too.
i'm a bit dissappointed, but that's life.
track.focus'd
12-08-2015 05:53 PM
