how can i find the TDC on a engine with a ajustable pully
just finding my feet
thats got no makings on it ay all
when my head was fitted and cam timed up there was no markings made on the pully for TDC
can i do it by the rocker arms when one of ems fully open or not
i was thinking spark plug holes but on a CVH its not gonna be as acurate as a cossie engine is it
anyone know
anyone know
well the bottom pully is a 1.8 sierra one with no marking as its been machined but im thinking about taking it off
also as the cams timed up dont that mean the crank timing has been played with
Baby Cheesus
when ya time a cam ya set the engine to tdc and then the valve to fully open or closed ( know ya know why i someone else to do it ) and move the crank on the round 360 thingy that ya place in the bottom puly i thought
ok brom now ya confused me
so can ya measure the tdc with a dial gauge on a rocker of a valve or somink
as i really dont wanna remove the head to find the TDC and then set it al again
Proven Legendary Status
What Broms getting at is that knowing where (true) TDC is. Is only one stage of the complete operation. You still need to set the vernier so that the valves are fully open at the specific angle as set by the cam manufacturer.
Without being too nasty. If you havent got a clue. (and to be honest it sounds like you havent) Then get someone who does, to run you through it.
Without being too nasty. If you havent got a clue (and to be hinest it sounds like you havent) Then get someone who does to run you through it.
hey ive got a clue what TDC is, the engines been timed up perfectly as that was what i payed for, the part im gonna be fitting is the cps wheel that needs the tdc to be perfect and as theres no marking im asking how to find it, getting TDC whe the heads off is soooooo easy and timing a cam is easy as ya get the timing on the cam for it
i wanna know what tdc is when its all together, i can do it on a cossie engine as gareth said
now paying someone requires removing the engine so i gotta hire a crane, get a vehicle to stick it in so i gotta hire a van, then i take it to a place that knows what there doing like i dod to time the cam as it was ment to be soooo hard and then get told 2 weeks max and then wait 2 months for it and the estimate of 80 quid ends up being 230 quid plus vat as the deck of the block required cleaning
as for fitting a cps wheel on a bottom pully with no marks on either how to i find that is what i really wanna know
JoeyBoyden
04-01-2024 02:36 PM
CabrioTurbo
01-08-2015 11:04 AM
lockie
31-07-2015 10:03 PM
