drilling out snapped bolts
any tips?
I got 3 bolts I need to drill out of a sub frame
Def cant make them budge with a mole grip on the broken end... they are far too rusted in place. All the drills I have are blunt!!
Alex
Alex
Use a sharp preferably new drill bit and go slow and stop from time to time to let the heat dissapate otherwise you'll fuck the drill bit. Oh and dot punch the bolt so you can get started straight
Originally Posted by Stu @ M Developments
If theres enough protruding, weld a nut onto it then you can use a spanner
PassionFords Creator
But then id just drill a small hole and use my snap on bolt extractors
It's a bastard when that happens!
Easyout dont work unless the bolt has just shered of and not snapped off due to rust. Get a Dremel and use a carbide burr and grind a hole in it all the way though if you can then start to go to 1 side and just brake the pitch on the thead then use a small chisel or punch and colapse the rest of it out then run a tap up it
if ya have any problems and im not taking the piss but speak to cowboi, hes the fooking Don at things like this, his a shit hot engineer and sorted out wheel nut for a mate of mine that we gave up on and he sorted it and also he sorted a snapped stud in the head on me spare RST engine and done it spot on first time no fooking about
some people have a skill, some people dont tbh and hes fooking genius at stuff like that
Originally Posted by J871yhk
arr thats why I have NEVER got easy-outs to work...
I only ever resort to them on rusted in things! DOH!
thanks PJE!
Alex
thanks PJE!
Alex
Well if you can weld it that means you cant get the gas in there iver Well i belive your a bit fooked Alex
07-10-2015 12:56 PM
DavidK
27-09-2015 02:55 PM
