help!!! ignition probs...
Old May 6, 2005 | 09:22 AM
chiz's Avatar
chiz
Default help!!! ignition probs...
i know it aint exciting cos its only a 1300 chapper n not a cvh turbo, worth or the like but its my runabout so please help!!!
problem is shes only runnin on 2 cylinders. ive changed plugs n leads and no change.
now this engine is the 1.3 ohv hcs engine, which runs with DIS (Distributerless Ignition System) so basically rather than a coil setup uve just got a ignition module bolted on side of block (my xr2i has the same setup on the efi, bolted on side of head if that helps??)
tryed usin another module off a 1400 cvh with DIS but no change , still only firing 2 plugs!!!! nos 1 and 3 to be exact ( firing order 1,2,4,3)
so................. suggestions please!!!!!!
Old May 6, 2005 | 09:56 AM
St3V3_C's Avatar
St3V3_C
change whatever feeds the module then - is there something between that and the ecu?
I *think* you have 2&4 firing at the same time on one half of the module, and 1&3 firing together on the other half - so it sounds like half of the circuit feeding that is not there.
Old May 6, 2005 | 10:21 AM
chiz's Avatar
chiz
cheeRS mate gona take that section of loom out and check it tonight!!!
gonna be sumthin stupid i reckon cos its such a simple setup!!!
Old May 6, 2005 | 10:43 AM
St3V3_C's Avatar
St3V3_C
If the loom looks generally OK, then I would be checking any modules along the way first mate - especially if you have another car you can just swap them from
Daniel Howard
17
Sep 26, 2015 12:39 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
beller
Sep 21, 2015 04:13 AM
marky_g
Sep 12, 2015 04:26 PM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
