cosworth overbored engine question
The engine in my car has recently been rebuilt but with a 1mm overbore on a 205 block, am i limited to how much power i can run due to this overbore?
Hi....my opinion is liner it so you can use std size pistons....its what i did on a stage 3 running 2bar peak .....The liners are stronger than the block so you take all cracking risk out.....1mm is pushing it imo although i have never run it so can only guess.
m8 if the engine shop checked the block and was happy to bore it then dont worry , i have a 205 block and lets put it this way its bigger than yours , stage 3 would be fine, as for 205 blocks being weak - its bollox , they are differant in casting but detrimental i think not - the argument will go on for ever m8, just be aware the 205's are generally older then the 200 series. personally wouldnt have a 200 block due to past experiances and thats from a competition point of view not just road driving m8
Phone Stu @ MSD in the morning and he will tell you what he told me. 380 brake is about the limit with 1mm oversize (just rebuilt mine with this)
Mine is going back on stage 3 for now.
How many of the people who've replied are engine builders?
not going to go into metalurgy of this but cast gets stronger with age..older the better
i would rather an old 205 over a new 200 any day of the week....an old 200 is a different matter though
Its far more complex than a single figure TBH and im sure i will have mentioned 4wd Vs 2wd block flex due to grip as well unless i was very busy
As Mark says, theres plenty of ultra high torque motors running well on 205s but sometimes bolting that successfull motor into a 4wd car will crack it.. lol
Yes i build my engines...but not on 1mm over.....as i always run liners
Stu.....of course 4x4 needs the 200block due to increased grip which increases the chance of cracking...a 2wd is shit for grip if left,so in reality you could put 800bhp thru a 1mm oversize block and not crack the fucker
Pugo
Just what I thought
I have a 205 block that is 1mm overbore, has done 3k since rebuild,2k of that at 22 psi stage 3 T34/greens/500 i/c, L8 pectel bb etc, mapped by Paul Hills @ 365 bhp at flywheel, he said if i were to fit greys & cams i would see about 400 bhp but when i told him it was on a 1mm overbore he said keep it at stage 3.
Simon.
Simon.
IMA's make believe world of tuning
