General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Looking at this with your expert eye, what pearls of wisdom and words of experience can you share to point out anything I need to know....I was a bit disappointed in the end result, was hoping for around 500 but he ho... Operator says he had to back of at 175/177 because his rollers are only rated to 180 but said it would pull well into the 180s confirming it has been remapped but no where near the dps automotive claimed 535bhp...standard performance pack cars are 487bhp and 174 top end....
It's also meant to be around the 660nm of torque.... The car pulls like fuck through all the gears and doesn't feel lacking in any way, it still scares me after 18 months.... And it is a 12 years old car and I just passed the 100000 miles mark today....
Ime na tuning is rarely worth the cost without changeing mechanical parts, I'd personally leave it and wait til have a turbo motor then start the tuning fun
I'm not planning on spending big money chasing big power, was just curious where its at... You can get a bolt on supercharger kit for under 10 grand but 650bhp+ would be mostly unusable
Where does it tell you what gear it was in....?
Its a 7 speed auto but you can paddle shift it manually....
What's the best/normal gear to do a run in....?
To be fair he briefly mentioned 4th and 5th.... I think the top speed was a seperate run through the auto box.... To be honest it was a bit pointless, he didn't really explain that much....
I think when you take your car to have it set up on the rollers that the guy who is doing it explains everything to you and is happy to answer any queries you have. I can only go on my time at MSD where they explain everything in depth and you get a nice cup of tea! After all they are the experts who should be able to leave you feeling 100% satisfied when you leave.
I think when you take your car to have it set up on the rollers that the guy who is doing it explains everything to you and is happy to answer any queries you have..
It has been run in too high a gear. Torque output on this N/A engine isn't a lot so it could easily have been run in a lower gear.
Power is still climbing so if it revved out it would have made more power. However don't expect 500 as it simply won't do it. Highly tuned N/A engines will reduce power over time.
Like i have said before, the ONLY reason you can remap these cars and gain a power increase is the throttle body is not fully open from the factory in order to restrict it - the identical higher power engine is used in the E63 unrestricted.
