Cosworth 4x4 oil pump options
Cosworth have remade the original YBO 852 4x4 oil pump you can get them from modatek there Ł400 including vat
http://modatek.co.uk/wp-content/uplo...ce-list-V3.pdf
Steve
Steve
On all the new oil pumps when I fit the Emtron Ecu installation I always recommend fitting a oil pressure sensor to the ecu to cut at a drop in oil pressure. This has already saved one engine so just a oil pump change rather than a destroyed engine which saved a possible 15k engine.
Mark
Mark
Steve
Steve
Mark
Mark
Very clever tech! For someone that has spent shit loads on their engine would be a very essential feature. Years ago I had that nightmare of sudden oil pressure drop followed by bottom end bearing failure which is not good!!
Unfortunately not , as the wet wipe that was mapping and fitting the ECU install didn't put the safety features in place , luckily after a rebuild and set up via mark Knight and stu it was all set up properly.. lesson learnt .
