Cossie engine rebuild - what head gasket to choose?
Hi,
The Grp A head gasket of my 4x4 cossie let go last week. As I pulled the head off I also noticed some engine wear so I am going to rebuild the engine.
The engine is running a MSD 380 bhp setup with T34. Thats enough for me (and the standard drivetrain) so I am not looking for more power.
As the bottom end and cylinder head will be skimmed flat I am looking for the best head gasket to use for my setup. I am not going to longstud the engine so I will use the normal headbolts.
At the previous head gasket change in 2007 I purchased a Grp A head gasket and some 10.9 head bolts from Woodford Garage. I dont know if these are the right head bolts. But from what I have read the original 4x4 KXA1000 stretched head bolts are very hard to get these days.
I see the Victor Reinz Grp A and also the WRC 4 layer Mountune head gasket which Matt Lewis is selling. Is the WRC the best head gasket to buy when using standard head bolts?
And what are the best available head bolts to use?
Hope you guys can help me out to get it sorted.
Multilayer gasket Is best, if I was you I’d long stud it while it was apart and it will be fit and forget
To be onest it's all down the you budget mate keeping it cheap standard head bolts and a WRC multy layer head gasket witch for your power will be fine as long as your block is not cracked . The best way the same gasket but long studded but then you have the cost of the shipping the block to and from how is going to do the work and the stud kit . And there is not a lot of places around that can do it . And again it's wots your budget as if your putting pistons in there is Ł500 on it's own
Rsturbo519
18
16-03-2014 06:37 PM
Chip
145
10-01-2011 08:17 PM
richm
13-01-2005 11:23 PM
