Camshaft damage, advice please (pics added)
Was supposed to be having the timing belt done today on my puma 1.7 engine while its out.
A mate of mine offered to do it but while doing it I seen him damage the end of the camshaft, basically because from what I can tell he had the locking bar in place while trying to loosen off the cam pulleys, this caused the end off the shaft to chip off where the locking tool was. he immediately said 'can't do it now' and left. So I'm left with a damaged cam and no cam belt as he took the old one off.
here's the pics what do you think?
As above - There's a special tool that locks into the pullies to slacken the pulley bolts.
Bit late now. https://www.ebay.co.uk/itm/FORD-ROTU...-/111989188349
cheaper version https://www.ebay.co.uk/itm/LASER-TOO...gAAOSwX~dWomAl
Seen this happen mAny times working in garages over the years, happened once to myself stupidly but we all live and learn and I certainly didn't make that mistake again! As long as the broken piece is retrieved then it causes no harm at all as that part is only for the locking of the cams. Nice of him to fook off and leave you in the shit though! Easily remedied
Theres a hex on each camshaft to hold with a spanner while tightening/undoing
I've done the same thing with a Focus . I couldn't just fuck off tho ! By the looks of it you can still get the timing bar I the end of the Cam so you should be still good . I'd use a pair grips to hold the cam when you nip the pulley bolt up
I did something similar to a fiesta when the crank locking tool slipped and the engine turned while I was loosening the crank pulley bolt.
I retrieved the broken bits off both camshafts and I was still able to time the engine up and complete the job.
ok thanks for replies, made me feel better anyway, ill see if i can get a mobile mechanic out this week to do it. wish id done that to start with.
oh, and i sent my 'mate' a final text message. he replied with with some shit about how he didnt want anything for doing it so what am i complaining about.
cunt.
cunt.
easy if you know what your doing, ill do basic things to the car myself but things like this are best left to a pro Imo. I don't fully understand it really, I've only got to get it slightly wrong and I've caused myself a load of grief. If a so called mechanic has fucked it up already what chance do i have at getting it right!
Glenn, very detailed information which for someone with good mechanical skills is probably straight forward but for st220kyle may be, as he has said pretty difficult ,so he will be happier to get it sorted out by a proper qualified mechanic.
tooly80
14-04-2011 11:25 AM
dave_s2_rst
23-12-2010 04:24 PM
rsdan
45
13-10-2007 09:00 AM
L33 BYT
22
18-09-2004 10:15 AM
L33 BYT
12-08-2004 07:56 PM
