No Compression - No Damage! WTF NOW! CRY - Pics Added
Old 16-09-2004 | 02:47 PM
L33 BYT's Avatar
L33 BYT
Default No Compression - No Damage! WTF NOW! CRY - Pics Added
Righjt quick sum up,
Head gasket went,
Had head skimmed and new gasket, rebuilt seemed a little fluffy, compression test showed only 3 bar on one.
Head off no sign of physical damage to be honest no explanantion.
Are new blocks available or can you get them refaced at all.
Goonna start from scratch or try and find a recon engine from some where.
Old 16-09-2004 | 02:53 PM
adamS2RST's Avatar
adamS2RST
Still no luck with it all then Lee?
Old 16-09-2004 | 02:54 PM
DOO's Avatar
DOO
new block`s or engines are not avab from FORD anymore for RST
Old 16-09-2004 | 03:04 PM
L33 BYT's Avatar
L33 BYT
Right this is the second Head gasket she has had. Must be a block issue. HEad been checked when was skimmed.
I know fact, that a) the head was put on correctly b) Cam timing was 100%
Any one have any contacts for recondioned Turbo CVH lumps?
No mate. Was hoping to see a bent or damaged valve woould explain No compression.
Old 16-09-2004 | 03:05 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
Surely at 3psi and no sign of obvious damage, then the test and/or equipment must be questionable?
Old 16-09-2004 | 03:06 PM
Christian and Beccy
#1 in Spelling Club
Incidentally, what were the other 3??
Old 16-09-2004 | 03:09 PM
L33 BYT's Avatar
L33 BYT
9 PSI on 2,3&4
Tought the same, but all ok every time on the other cylinders. Even tried anoter tested.
Weird though cos tried a few times in case my head was playing tricks and was reading 0. Now even one of my farts would cause at least 1 PSI so I was thinking head off and there would be a problem staring me right in the face.
Old 16-09-2004 | 03:17 PM
Christian and Beccy
#1 in Spelling Club
I assume you mean Bar not PSi??
Old 16-09-2004 | 03:18 PM
James Porter's Avatar
James Porter
Had the same prob turned out to be a cracked piston between the rings.
Old 16-09-2004 | 03:33 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
shagged rings??
Old 16-09-2004 | 05:39 PM
L33 BYT's Avatar
L33 BYT
Would that really loose all Compression though?
Also if the rings were shot would she not smoke like Dot Cotton?
Nothing visual on the Head sagket either.
Would the face of the block be shot?
Old 16-09-2004 | 05:40 PM
L33 BYT's Avatar
L33 BYT
And yeah sorry mean BAR!
Old 16-09-2004 | 06:18 PM
L33 BYT's Avatar
L33 BYT
If I had an issue with the lifters on this cylinder and it was causing the valves not to open this would still give me a reading wouldnt it???!!!!
Old 16-09-2004 | 06:48 PM
ML's Avatar
ML
have you put the spacer plates on that go under the rockers
Matt
Old 16-09-2004 | 06:49 PM
L33 BYT's Avatar
L33 BYT
Yeah. I did indeed,
Old 16-09-2004 | 09:16 PM
rswoza's Avatar
rswoza
have u actually ran the engine? does it run? maybe a poor seal on the compression tester on one of the plug holes...just a thought
Old 16-09-2004 | 09:31 PM
apples24's Avatar
apples24
get pics up
Old 17-09-2004 | 10:12 AM
L33 BYT's Avatar
L33 BYT
Yeah engine done bout 100 miles since head back on.
get pics up
Right will do.
Old 17-09-2004 | 11:12 AM
L33 BYT's Avatar
L33 BYT
Old 17-09-2004 | 06:43 PM
DazC's Avatar
DazC
Take some bigger piccies focused around the cylinder you are having problems with mate.
Old 17-09-2004 | 06:47 PM
Smit's Avatar
Smit
The 60ft Launch King
cylinder number 3's valves look different to the rest..
looks like damage near the no.3 exhaust valve or is it just my vision
Old 17-09-2004 | 06:59 PM
L33 BYT's Avatar
L33 BYT
Will do
Wish it was. Thing is its on bore 1
Old 18-09-2004 | 10:15 AM
L33 BYT's Avatar
L33 BYT
May have engine out today. See if the pistons are at fault!
155lee
14-08-2015 12:21 PM
taylora1409
12-08-2015 01:06 PM
