Good Old Cosworth Centre Diff
Old Oct 16, 2018 | 10:55 AM
knights19's Avatar
knights19
Default Good Old Cosworth Centre Diff
Hi All,
Very old subject I'm sure but I've searched lots and not got an answer.
I have a type 9 4x4 box in my project car build which runs the gearbox the wrong way around so I get too much torque to the lighter front wheels (engine in back). I plan to remove the centre VC and weld up the planet gears to make it 50/50 torque split and then increase the lock torque in the viscous by uprating the fluid.
I can't see why it shouldn't work as the viscous would still allow enough slip front to rear to stop it locking the drivetrain up, I would still get wheel spin at the lighter front end from standing start but then the viscous should lock to transfer the power to the rear where the weight is. All I'd be doing is removing the 'torque' split feature of the centre planetary gears.
Thoughts?
Old Oct 16, 2018 | 11:17 AM
robrs2's Avatar
robrs2
Which Gears?
If you weld the gears in the centre diff then it locked so 50/50 split with not differential effect so no slip at all
Old Oct 16, 2018 | 12:05 PM
big_wasa's Avatar
big_wasa
I had a Scooby with a binding centre diff and the front wheels would skip when turning. It soon shagged the wheel bearings.
Old Oct 16, 2018 | 01:00 PM
knights19's Avatar
knights19
But it still has the viscous coupling in the same unit so I would presume there would be sufficient slip in that to stop the skip at slow speeds?
Ideally 50/50 planet gears would be the way to go but .... Hen's Teeth.
Old Oct 16, 2018 | 01:03 PM
knights19's Avatar
knights19
BTW, car is for tarmac hillclimbs. some wheelspin off the line should lock the viscous but after that it should cool down again and allow some differential?
Front/rear diff are same ratio, tyres all same size.
Old Oct 16, 2018 | 01:32 PM
Marc sierra's Avatar
Marc sierra
I'm not even sure it will be a 50/50 split if you weld the planet gears. But even if it would, the front and rear propshaft cannot turn at a different rate anymore because you welded that part. The viscous is normally slowing the difference between the turning rates, but if it's welded the viscous doesn't do anything anymore. With the front and rear propshafts only being able to turn at the same rate the car will only go straight.
Old Oct 16, 2018 | 01:54 PM
knights19's Avatar
knights19
As I understood it the input to the 'complete unit', initially runs through the planetary gears to give the torque split, transferring the 'turns' from the input shaft to the outer case. The outer case is toothed to the plates of the viscous and the other plates are toothed to the output shaft.
I theorise that I am only welding the torque split part of the unit leaving the engagement part of the viscous to still rotate. it would only completely 'lock' to permanent 50/50 when the viscous fluid got hot enough.
Old Oct 16, 2018 | 02:00 PM
Caddyshack's Avatar
Caddyshack
Bara put an uprated Viscous in my Mt75 Oppliger box, It has 60nm written on it in his blue pen, he said it improves the car handling anyway.
Old Oct 16, 2018 | 02:27 PM
knights19's Avatar
knights19
That would lock the viscous earlier which in your case would transfer more power to the front where the weight is when the rear wheels slip. Would help mine too but I'm getting too much initial spin as my bias is reversed to 67% front which unloads more with the weight transfer. May have even fried my VC with so much spin.
Old Oct 16, 2018 | 03:15 PM
Caddyshack's Avatar
Caddyshack
Thanks for the explanation...makes sense. The wheels did / do spin first at the rear and when it pushed power forward I did occasionally get a big tug of torque steer which was scary in the wet (it has Quaife up front) but I am hoping the new suspension setup will help to cure that as my compression struts were aparently in an odd mounting position before.
Old Oct 16, 2018 | 05:58 PM
COLEYST200's Avatar
COLEYST200
You need to do some research into your problem as welding it and making it 50/50 will not be good .
i run a skyline gtr R32 gearbox witch I can make 50/50 on demand I only use it when putting the car on a trailer as the car jumps all over the place when turning . I've used it on track and the car just pushes on in the corner,s
Old Oct 17, 2018 | 08:22 AM
knights19's Avatar
knights19
Get what you are saying, but I currently have a 67/37 split so I get a heck more push on than yours at 50/50 and mine wouldn't be 'locked' as it still passes drive through the viscous coupling. In my case 50/50 would be better than what I have I think.
Old Oct 17, 2018 | 04:31 PM
Marc sierra
It doesn’t pass the drive through the viscous. The viscous only does something if there is a speed difference between the front and rear prop. But a speed difference cannot occur if front and rear prop are welded together through the planetary gears.
Think of it as a normal (rear) differential. When you weld the planetary gears together both outputs are locked solid. A viscous unit on a welded rear differential doesn’t do anything anymore either.
Old Oct 17, 2018 | 05:41 PM
dojj's Avatar
dojj
Resident Wrestling Legend
the planet gears do the torque split front rear, the viscous coupling does the locking
so what you need to do is fit a solid centre viscous, it's the big cylinder thing and it's easy enough to get to, but welding it up is going to be much harder as they are made of aliminum i think
you could just get the fluid pumped up or drill a hole into it to let the fluid out and then fill it up with other stuff
Old Oct 17, 2018 | 05:52 PM
Marc sierra
There is some great info on the centre differential here: https://passionford.com/forum/ford-e...ve-system.html
Old Oct 18, 2018 | 07:17 AM
knights19's Avatar
knights19
Now this was a big step to help my understanding!
I always thought the viscous part was the link to the front prop, not at the rear prop. Of course it's not looking at the pics (my box is the wrong way round to confuse things).
Does this mean that when the viscous locks, the drive split remains the same, just more 'drive' is sent to the front or does it lock the reduction gear?
Edit:
Answered it myself, no it just transmits the drive but with the same torque split. I need to get a centre diff made to give me 50/50.
Old Oct 18, 2018 | 08:25 AM
knights19's Avatar
knights19
Still brings me back to:
If I weld up the planetary gears to eliminate the torque split I get 50/50. The viscous will then be redundant as propshaft speed difference will not be possible. I will get some driveline wind up and tyre jump in the paddock but under power when there is tyre slip anyway it shouldn't present a problem. Yes?
Old Oct 18, 2018 | 08:41 AM
Marc sierra
On a rwd vehicle when the rear wheels are locked together (welded diff) the car jumps a bit on tight corners. But if the centre diff on a 4x4 is locked I believe you will get very serious understeer, as in that it doesn't even want to turn in at normal road speeds.
Old Oct 18, 2018 | 08:43 AM
knights19's Avatar
knights19
Yeah but I get that now because I have a 70/30 split to the front.
Old Oct 18, 2018 | 08:46 AM
Marc sierra
Well you can always try of course. If it's not a success you can revert back (although you will need a replacement centre diff). The best option would be still be to find a 50/50 split centre diff, as was available for motorsport.
Old Oct 18, 2018 | 08:49 AM
knights19's Avatar
knights19
Anyone have one kicking around they can let me buy?
Old Oct 18, 2018 | 09:08 AM
Caddyshack's Avatar
Caddyshack
Why not convert to skyline box and then use the controller so you have as much adjustability as you could ever really want?
the controller I used had yaw sensing, you could run it 2wd, front bias etc.
Caddyshack's Avatar
Caddyshack
i LOVE that car and it should be in the sexy women thread
Old Oct 18, 2018 | 09:20 AM
knights19's Avatar
knights19
Yeah but that's a whole bunch of work again. Might go that way if I decided to start from scratch again but a bit late now. Would be ideal though to give better control. Mind you, the 6R4 was always a pig to drive, so at least mines authentic in it's character. First hillclimb I did got over-boost issues and under-steered straight off into the tyre wall !!
Old Oct 18, 2018 | 11:26 AM
Caddyshack's Avatar
Caddyshack
I can ask Tony if he is going to collect the complete set up I sold him 2 yrs ago but has not collected. I had everything including a 500 ecu to run the box and has the adapted bellhousing etc.
It it sounds like you need something to make the car more friendly
Old Oct 18, 2018 | 12:16 PM
knights19's Avatar
knights19
But would it be any better? Gearbox is still the wrong way around so whereas it would normally be RWD with control to the front it would give the opposite for mine unless you can run it as 100% RWD OR 100% FWD?
Mines the Type 9 too, not the MT75?
Old Oct 19, 2018 | 02:55 PM
Caddyshack's Avatar
Caddyshack
Not sure if you can go 100%fwd. I know what you mean though about how yours is run back to front.
I didnt think the type 9 could handle all that much power?
I toyed with the idea of building a 6r4 replica and my ideal would have been a crashed 911 turbo 4wd as the donor drivetrain.
Old Oct 30, 2018 | 07:46 AM
knights19's Avatar
knights19
Had the box rebuilt at 1stMotion trans, should be able to cope with 280bhp but he has had people run more in the cossie days with standard boxes. Mitsu engine is 285.
911 turbo set-up would work but not a cheap option I would guess
Old Oct 31, 2018 | 09:57 PM
stevieturbo's Avatar
stevieturbo
C**t
An open centre diff would probably be better than what you're proposing ?
If you only need the drivetrain to handle 280hp....surely Porsche stuff would be plentiful and cheap ? It's only really the turbo boxes and the like that carry high premiums.
Although their transaxle format would of course be very different than what you're currently using
Old Nov 1, 2018 | 08:05 AM
knights19's Avatar
knights19
Have you read the above Steve?
Porsche would be no good after thinking about it, transaxle would be too far forward as the engine is rear of the driveshaft line in the Porsche, no good for a short wheel base Metro
Old Nov 1, 2018 | 08:55 AM
Caddyshack's Avatar
Caddyshack
You could run it as open diff as Steve says though. Do you have slippy diffs in the front and rear?
Old Nov 1, 2018 | 09:10 AM
knights19's Avatar
knights19
Are you pulling my leg now?
Open diff is giving me 67% torque split to the front which was the reason for the post in the first place. Open diffs front and rear. A LCD in the front would make the understeer worse, not really needed in the back as that's where the weight is.
I'm going to weld up the centre diff and give it a try, it's not like it's a road car and there are people running welded rear diffs without problems.
Old Nov 1, 2018 | 09:35 AM
Caddyshack's Avatar
Caddyshack
I thought yours had a viscous coupling which set the torque split? I was thinking that if you put an LSD in the front AFTER the diff was fully open in the centre it may help you gain lost traction.
I do not have a clue how the centre diff works, especially not in reverse LOL.
Old Nov 1, 2018 | 09:56 AM
knights19's Avatar
knights19
The centre diff has 2 parts. Epicyclic gearing to give the split and the viscous coupling to transfer drive when the is a speed difference front to rear. I could get a stiffer viscous but that won't change the torque split and would likely burn out as I get so much slip/ speed difference.
I could put an LCD in the front to stop the one wheel spinning but likely would get both spinning instead as there's no weight on the front, giving more understeer.
Old Nov 1, 2018 | 11:26 AM
Caddyshack's Avatar
Caddyshack
Gotcha
I have Quaife ATB in the front of my Pug Cos (engine in front) and then Supra LSD in the rear and it drives pretty well although doing a 3 point turn feels like the handbrake is on. I just wonder if the slip could be reduced with an LSD but it might need to be set quite loose...as you say it is light on the front. It seems like one of those age old modified car compromises / frustrations, I have experimented with so much on my car and people thought I was daft as every time it was nearly finished I took it all apart again but I am confident I will get close in the end and I enjoy the journey (sometimes)
Paul500+
16
Aug 7, 2013 09:08 PM
jpbaginski
Mar 19, 2008 10:30 PM
jpbaginski
Dec 5, 2007 05:41 PM
martinmace
Apr 12, 2006 05:13 PM
p_jay78
15
Mar 17, 2006 02:35 PM
