Sponsored by:
Sponsored by:
Coolant flush advice
Old 13-08-2018, 09:13 PM
Lee Reynolds
Lee Reynolds's Avatar
Default Coolant flush advice
I've always avoided using a flush of any sort. I only ever flush with clear tap water and then replenish with the correct mix of coolant and water .
However, I have a car that the oil cooler had let a little oil into the coolant . When I fit the new oil Cooler I want to flush the system and remove any traces of oil for obvious reasons.
Can someone recommend a flush ? As I say I've never used any sort as I was always led to believe it can cause issues .
Tia
Old 13-08-2018, 10:17 PM
studabear
studabear's Avatar
I've heard of a couple of scoops of washing powder and clean water run it for a bit then flush through with clean water again.
Old 13-08-2018, 11:05 PM
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
Washing powder dose work few scoops filled with water run it for a day. We have a special flush at daf for when coolers go in the trucks. We mix it with the water then send them out for the day to work. Really good stuff
Old 14-08-2018, 06:25 AM
gcfcos
gcfcos's Avatar
We use washing detergent, the liquid version of washing powder
Old 14-08-2018, 11:35 AM
Lee Reynolds
Thanks
I'd heard washing powder but didn't wanna suggest it and sound stupid 😂
Old 14-08-2018, 04:13 PM
stevieturbo
C**t
stevieturbo's Avatar
And make sure you flush everything...rubber hoses will deteriorate in contact with oil.
Might be worth doing a couple of times.
Old 16-08-2018, 08:08 PM
Lee Reynolds
Flushed 20 times , with clear at first , then some washing gel , then water again ! Seems to have cleared it well . Tipped back up with coolant and will see how she goes
fordsteve77
Escort MK 5 / MK 6
22-01-2016 07:50 AM
scottma46
20-02-2014 09:21 PM
hogdog
15-03-2011 11:40 AM
rob w
22-10-2005 05:49 PM
Quick Reply: Coolant flush advice
