Escort MK 5 / MK 6 This forum is for all things about the Ford Escort MK 5 & MK 6.
Flush refill coolant is there a bleed sequence...???
Old Jan 22, 2016 | 07:22 AM
fordsteve77's Avatar
fordsteve77
Default Flush refill coolant is there a bleed sequence...???
Right flushed me coolant out of the mk6 cabby 1.8 zetec.
Is there a bleed sequence or bleed nipples anywhere when refilling so you don't get airlock...?
Or is just the simple fill start engine and squeeze the hose with filler cap off and engine running...?
Old Jan 22, 2016 | 07:50 AM
STeve's Avatar
Super Moderator
me personally I always do a double flush on my own cars then use correct coolant mix or pre mixed and purge in normal way, escorts are no different to any other car
fordsteve77
Escort MK 5 / MK 6
13
Mar 23, 2016 06:48 AM
willie rae
Feb 14, 2016 01:47 PM
nixon_2wd
Jan 31, 2016 06:41 PM
fordsteve77
Escort MK 5 / MK 6
Jan 19, 2016 02:13 PM
