Mk7 cabrio 1.8 NO speedo....HELP
well I thought I was mk7 as when I search for parts it says:
FORD ESCORT Mk VII Convertible (ALL) 1.8 16V 09.95-09.99
and I thought V is 5 and add II is 2 = 7.
Anyway the mph needle (speedo) is constantly at zero....?
do they run off abs wheel speed sensor on these
Ford ceased production after MK6, and introduced the Focus in the late nineties. Ford continued to sell the MK6 Escort alongside the Focus into the millennium.
You might want to try the easy bits first such as removing the cluster to see if the cable is fitted correctly, also check at the gearbox end for cable fitment. Of course not forgetting to check the speedo gear(little red item)
See link:
http://www.ebay.co.uk/itm/Genuine-Fo...sAAOxywh1S~gy1
Has the instrument clusters been fitted with lockwood dials, some people knock the needle or dont re-fit it correctly. See if you can pull the needle off the 'pin' and refit it again(if lockwoods have been fit).
I'm not clued up on the later Escorts as much as the MK3/4 models so I cant help too much.
See link:
The old mk7 Escort error is a bug bear but not helped when so many folk selling stuff get it wrong.
I'd be looking to try a new cable as a first and relatively cheap start. iirc the cable drive is actually in the box on the BC/IB5 and not a serviceable item
Moderator
speedo is mechanical and cable driven not electrical so will have nothing to do with abs at all, speedo itself or cable could be broken of simply fallen off rear of cluster, abs has sensor on each wheel which is electrical and prone to fail
hi i think you will find that not all mk6 escorts run off a cable drive to the box,but actually run off the ecu which picks up the the signal from the abs sensor and the pick up sensor for the flywheel in the gearbox
london_chris
25
03-04-2024 09:40 PM
Rs Gus
32
14-09-2016 07:39 AM
fordsteve77
Escort MK 5 / MK 6
19-01-2016 02:13 PM
