mtx gearbox conversion in to s1 escort
Old 25-04-2018, 09:16 PM
Martins1
Martins1's Avatar
Default mtx gearbox conversion in to s1 escort
I know this has been asked a lot of times, but what is the best gearbox to use and from what car to put in a s1 escort, and if anybody has got pictures of the mounts and any more info I would appreciate it
Old 25-04-2018, 09:31 PM
studabear
studabear's Avatar
What engine are you using?
Old 26-04-2018, 10:22 AM
Martins1
Martins1's Avatar
its a 2.1 zetec turbo 450bhp
Old 26-04-2018, 05:30 PM
slammedorion
slammedorion's Avatar
Focus RS Mtx75 then and cross your fingers...
Silvertop or Blacktop?
Old 26-04-2018, 06:54 PM
studabear
studabear's Avatar
As above no other option really.
Old 26-04-2018, 06:59 PM
Martins1
Martins1's Avatar
Silvertop
Old 26-04-2018, 07:14 PM
Martins1
Martins1's Avatar
are they a lot stronger than a standard mtx box, as I can see these being quite hard to get hold of
Old 26-04-2018, 08:34 PM
slammedorion
You’ll want the RS version as it’s fitted with a lsd
Old 26-04-2018, 08:55 PM
studabear
studabear's Avatar
I believe the bell housing is a bit bigger too as The FRS clutch doesn't fit in some of the other MTX boxes?
Old 28-04-2018, 10:07 PM
Martins1
Martins1's Avatar
does anybody know of one for sale
Old 01-05-2018, 09:21 PM
Gadget
Spanner monkey
Gadget's Avatar
Can’t see the box, but I’ve fitted an RS Mtx into this series one
Old 02-05-2018, 08:30 AM
bassboy
bassboy's Avatar
Hey Gadget, did the S1 ARB fit straight on with that conversion?
Old 02-05-2018, 02:56 PM
slammedorion
It that silvertop or blacktop? Gadget?
Old 02-05-2018, 04:38 PM
massivewangers
massivewangers's Avatar
I THINK(!) the bell housing is the same on all MK1 Focus hydraulic clutch MTX75 boxes. The only difference is for diesel lumps, which have the front mount starter. The FRS clutch problem occurs when using a rod change box from a MK5/6 Escort.
It's hard to find answers though. I've got a MK1 Focus box in my MK5 RS2000 and can't get the RS2000 flywheel/clutch to work. About to try a MK1 Focus 2.0 flywheel clutch instead.
Old 02-05-2018, 06:38 PM
Martins1
Martins1's Avatar
Silvertop
slammedorion (02-05-2018)
Old 02-05-2018, 06:40 PM
luke19790_3
luke19790_3's Avatar
I’m using a rs2000 box with a standard 2.0 flywheel and frs clutch. Don’t have any issues.
mine is on mef/s1 setup with coil overs
Old 02-05-2018, 07:14 PM
massivewangers
Think it depends on which RS clutch you use doesn't it? Some hit, some don't.
Old 02-05-2018, 07:21 PM
Martins1
Martins1's Avatar
Have you got any pictures of the gearbox install
Old 02-05-2018, 07:50 PM
luke19790_3
I just made new brackets which sit on the original s1 mounts
Old 02-05-2018, 08:08 PM
Martins1
Martins1's Avatar
does this box use cables and is the ratios ok
Old 02-05-2018, 08:21 PM
Martins1
Martins1's Avatar
if I can't find a frs box, does anybody know what mtx75 box to use and out of what car, I seen people talk about the 2.0 mondeo petrol, would the gear ratios be ok, I know it hasn't got a lsd but I can buy one separate
Old 02-05-2018, 10:18 PM
massivewangers
I think the ratios in the standard 2.0 Focus are pretty much the same as in the FRS, it's just the final drive that's a bit shorter.
Old 03-05-2018, 06:42 AM
Gadget
Spanner monkey
Gadget's Avatar
Hi mate, had the modify the drivers side cast mount bracket to clear the alternator but other than that it has clearance everywhere.
It's yet to have a shakedown so we'll see. It the roll bar is close to the box so at worst may need flipping to the other side of the tie bar.
Old 03-05-2018, 07:34 AM
colins2
colins2's Avatar
what inlet are you using Gadget
Old 02-07-2018, 08:54 PM
JesseT
JesseT's Avatar
I'd be very interested to see those too! Are there any pictures anywhere available?
Old 05-07-2018, 12:07 PM
rs milesy
rs milesy's Avatar
If you have a look on seriesoneturbo in the resto section, have a look at OVO and the moving goal posts, on page 2 there are some photos of a MK1 FRS MTX install they are the last pics posted up.
Old 05-07-2018, 07:47 PM
big_wasa
big_wasa's Avatar
I was going to ask that aswell
RUBY123
24-07-2015 10:10 AM
McGoo 69
25-05-2011 09:42 AM
jonny s2
13-09-2010 02:42 PM
turboben
03-06-2007 05:33 PM
graemewelch
29-12-2005 06:32 PM
Quick Reply: mtx gearbox conversion in to s1 escort
