Alarm! - urgent help needed!
hey, can any one help, i have an alarm on my car, one with a key fob that locks the car ect, i set the alarm and it locks but then 3-5 mins later the alarm just goes off and starts bleeping and flashing idicaters ect.
can n e one help?
cheers
neil
can n e one help?
cheers
neil
As above, check the bonnet, boot and door switches. If you have washed your car or it has rain'd heavy then water can sometimes find its way into the switches and short them causing the false alarm.
Remove the switches, get rid of the water and coat them in low temp grease or vaseline
still not cured!
iv noticed the interia light dosent come on wen i open the doors and it is set on the switch to come on, is the alarm on the doors operated on the same plunger?
i disconnected the bonnet plunger and this dosent solve it.
help appreicated because i cannot set my alarm at the moment.
i have norrowed it down to been a faulty earth or connect as the alarm bleeps 3 time so i looked on the handbook and 3 bleeps is earthing.
cheers
neil
cheers
neil
paceo
03-02-2016 10:31 AM
kosienutter
31
22-08-2015 09:55 AM
