Does diesel go off..
..... like petrol ?
My father in law has given me some diesel about 3yrs old but I'm unsure if it will be ok to use.asfaik diesel doesn't go 'off' , anyone know ?
Btw it's a 5 gallon ex army jerry can that will have been well sealed .just seems a shame to sling it away
Thoughts ?
Thoughts ?
No, it will be fine. Run it through a fine mesh gauze as you can get 'diesel bug' which is a black gloopy mess that will collect in the bottom of the can. Diesel will also absorb moisture from the air so the water content can be high, but as long as the can had a good seal it should be fine.
Yep, from the moment you put it in you should have bought a petrol...lol
It goes off.
Don't know how long it takes but when I used to work with fuel stuff in our old pipe work would be really wax like as if it had been in very cold conditions.
It would take an incredibly long time to go off, some diesel standby generators could sit for years with the same fuel, and they've no problems
Only concern if container wasnt sealed is the fuel can absorb moisture.
3 years is fuck all though.
Unless it's filled to the brim and fully sealed it will absorb moisture.
Like old fuel tanks that are half full will rust on the inside as moisture is present.
He's not sure if it is 3yrs or a little longer lol.not opened the jerry can as yet so not sure if it was brimmed, it's an ex army "plastic" jobbie so is that more or less of an issue re moisture? ?
Is there any way tell if it's got water in the fuel or is it simply going to floating in the diesel
All their filters should have water traps and alarms
Hell, even car diesel filters used to have water vent taps and some water sensors on them !
Given how fussy common rail etc is, I'm amazed they dont still have these
Lol some funny replies here, I had a crawler sat for over 10 years new batterys and unseized it ran like a top on the diesel in the tank, paranoia tells people oh it must be knackered, lol it will be fine
Originally Posted by scoooby slayer
All our 1970s equipment have water traps surely this new stuff does, our newer machines do with the drainer on the bottom to drop the water at service time.
Work thinking about it had filters like on a truck and there was all sorts in the fuel, maybe it had a leak into it somewhere I don't know
cossie fan (unluckerly)
Big dafs don't have water traps un less spec'ed by customers. Modern diesel has a percentage of bio in it that gives us issues. Companies like McDonald's who make there own have terrible issues with fuel. I've been called out there before and had to change fuel filters on 3 or 4 different trucks. When you take a fuel sample and leave it for a few days all the crap sits at the bottom sometimes you can even see bits floating about lol. And foreign trucks crist fuck knows what poor standards they work too. The amount of lack of power Daf Aids you get from low fuel pressure. The fuel filters and tank stack filters are black with shit and you end up blowing out the fuel lines. With the euro 6 engine having such fine tolerances it's a real issue
When I worked for a van and truck hire workshops 2 of the tractor units were on long term hire to a company. They used to remove the first diesel filter and housing so they could run bio diesel. Everytime it came in for inspection and service we would fit a new filter and housing and they paid for it but soon as they got the Lorry back u knew they removed it straight away.
Depends who they are lol if they buy 30 trucks a year they have a lot of clout. Most trucks in big yards are owned buy leasing companies who the likes of Daf want to sell trucks to so they normally end up footing half the bill. Un less it's on a Daf repair contract then there can be arguments lol but normally then still get a lot of the cost wiped of the bill
that's bloody stupid if that's the case, all diesels need a drainable water trap, all my machines have them on the base of the first filter, then 1 or 2 more fine filters after that, it should never be an issue just drain off at every service, and if the filters get blocked machine will just stop running it doesn't cause any damage on any of my equipment, newest I have is a 2007 cat.
we have had to clean a few fuel tanks out with the sludge with this new diesel, so much had accumulated it just wouldn't drain off from the base drain taps.
These tractor units were doing serious mileage, the amount the company must have been Saving using bio diesel must have outweighed any repair costs. Never saw any pump issues with them. They bloody stank the workshop out mind lol
admanrs
29-08-2016 05:02 AM
fuzzy
23
20-04-2016 04:16 PM
madfortaryb
15
01-03-2016 06:33 PM
