VW emissions scandal
This is a bit more serious than exaggerating power figures or fuel usage.
But even exaggerating fuel usage figures can cost you hunderd's of million dollars in the US as Hyundai and Kia have found out.
What they basically did was use a software routine that could detect whether the car was undergoing an emission test or was driving on the highway.
When the emission test was detected the car was clean and complied with (strict) US rules. Otherwise they did not comply and produced 10 tot 40 times the amount of NOx that was allowed.
See: http://www.washingtonpost.com/news/e...tion-controls/
Yep, and a lot more than you think.
The fine will be huge, but then there are the other costs.
Extra emission rights have to be bought, all cars must be recalled (at least in the US), owners will complain that they bought the car because it was good for the environment and will sue, then after the update the use of AdBlue will double or triple and more owners will start law suits.
cossie fan (unluckerly)
it's a load of old bollox.
They can take any car off the production line and it will pass their silly tests. isnt that what they had to do ?
They've just bent the rules a little as to how they achieved it. I think they deserve a medal ! lol
I new a few play about with it like Merc and Citroen I think. I'm surprised more don't. If you ever work on a vehicle that runs it and you watch with the laptop via the nox sensors how much of a difference it makes on a warm day on a vehicle working hard and creating high nox levels it makes a huge difference
Some took the ad blue route some took the erg route ad blue is better. But must new euro 6 trucks have both. The new daf has both as ad blue only works as the exhaust system gets up to temp. So the egr is there to reduce emissions until the exhaust is up to temp. The egr also heats the engine and allows the exhaust system to get up to temp along with a veritable vain turbo and injectior that doses fuel in to the exhaust. Once up to temp and using the ad blue system the egr helps cool the cylinder temp. The emissions system on a truck is fooking complicated now
If it was there to be found, clearly it was not hidden.
If it passes the tests as they are required...what's the problem ?
The whole thing really is stupid, they must be changing the goalposts of the test or something to try and get money from them, or to help their local car makers
So given the vast array of info the car has available to it, it could be told to recognise all these things and perhaps run slightly differently.
I dont see that in any way as cheating. Cheating to me would suggest a car specifically modified to pass a test, and only that car would be able to pass.
But if any car can be driven off a production line or the street. Carry out the test it is required to do and pass...then it has met all the requirements of that test. There is no problem unless there are some dodgy deals going on somewhere within the US government
They lost and ended up paying 1 billion dollar. See: http://jalopnik.com/how-the-epa-won-...-be-1732109485
I personally find it a very good thing that VW has been caught. Other countries like Switserland, Italy, Germany, South-Korea are also starting investigations. The European Union is talking to their American counterpart, but I don't think they can do much, because of the way the EOBD law has been written. They forgot to add the penalties for infringements.
Now maybe I am biased as a cancer-patient and more cancer-patients in my family.
But I'll guarantee you, that you will change your opinion once you or one of your beloved ones get's cancer, especially when it's something the doctor's have never or rarely seen before.
Several big truck company's like Caterpillar, Cummins, Detroit diesel and others argued this in court pretty much the same way.
And no, it hasnt changed my opinion, but certainly it has been known for decades that diesel is a dirty carcinogenic fuel when it comes out the other end.
But when governments do virtually nothing to promote or encourage the use of cleaner fuels to build cars that will run on cleaner fuels eg LPG or E85 etc...and diesels when they work are cheaper to run...what the hell do they expect people to want to drive ?
So equally the governments are to blame for the popularity of diesels.
I dont see it as misleading.
What I do see as misleading is every single car manufacturers complete and utter lies about the mpg's their vehicles will achieve. That IS a scandal.
Carbon Crazy
Of course its misleading. The emissions tests are meant to represent emissions standards of the vehicle as a whole. So fudging the engine management to cheat it clearly is cheating.
Its a bit like putting a bung in your exhaust for a static track noise test, then removing it before going on track
Or having your head lights aligned then pushing a button that makes them dangerously dazzling once you left the MoT station
MPG isnt governed by law, emissions are. The manufacturers can get away with MPG figures because if you bother to read the small print, they will tell you EXACTLY what conditions the MPG figures relate to.
It's nothing like that. They are not having someone make changes to the car before or after a test. They can pick any car from anywhere and it will pass their test.
That isnt modifying or cheating in order to pass a test because every single car they pick will do the same, with anyone behind the wheel.
If it was only the cars that were chosen for test were modified or altered then it would of course be a very different story.
Carbon Crazy
Of course it is cheating. Would it pass a road side emissions test? no.
So its not legal then is it?
The conditions of an MOT emissions test are only that way as its the only easy practical way to do it. There is no mobile rig they can plug in a do a test drive, nor would they want to have to do that.
So deliberately fudging the ECU to change its map for an MoT test so it seems to be a low emissions vehicle is blatently wrong.
Funny how the law seems to agree by giving them a likely massive fine.
